OpenVPN "No such (key/crt) file" on LS300
Hi everybody,
I try to configure an LS300 for OpenVPN, I configured the VPN and transfered root certificate, client certificate and key.
But the VPN don’t start, in logs I get this errors :
Firmware is 4.4.5.011 for EMEA.
What is the cause of this errors ?
Hi rmelior,
Did you solve the problem? I facing the same issue and would be happy if there is solution to it. I have ALEOS version 4.4.7.
Best,
Peter
Thanks but I have tested after 4.4.7 upgrade : same problem :frowning: .
Too bad. I’m wondering if anybody could make the LS300 work using OpenVPN. We also use RV50 and there is no problem at all with the OpenVPN.
Hi @rmelior and @Weyep
Were either of you able to solve this problem? I’m having a similar problem right now but with a Shared Object (.so) file instead in my LS300. Funny because a week ago it was able to read the .so file. But now I’m receiving a no such file or directory.
Regards,
Josiah
