Hi people, i’m doing a small app on FXT, the goal is to open UART1 to communicate with an external device. I’ve done this successfully using FCM but i need to re-implement it using OpenUart APIs, because my final goal is to drive a microSD RS232 FAT16 drive interface, and i need to do this (in pseudo-code):
Open uartX;
Write command to uartX;
Disable watchdog;
for(i=0;i<512;i++)
Read buffer from FAT16 drive;
for(i=0;i<512;i++)
Enable watchdog;
etc...
Driving the microSD using FCM become a little bit hard to handle in my pre-existent code.
So, i have the following code:
#include "adl_global.h"
#include "adl_OpenDevice.h"
#include "wm_uart.h"
#include "adl_wd.h"
static const sGCbDesc_t uart1CbTab[] =
/* user data */ /* callbacks */
{ (void*)-1L, NULL },
const u16 wm_apmCustomStackSize = 1024*3;
static psGItfCont_t uart_if;
static sGItfCont_t uart_itf;
static s32 uart1_hdl;
void Init_uDrive_uSD_G1()
adl_atCmdCreate("at+wmfm=0,1,1", FALSE, NULL, NULL);
adl_atCmdCreate("at+ifc=0,0", ADL_AT_PORT_TYPE(ADL_PORT_UART1, FALSE), NULL, NULL);
adl_atCmdCreate("at+ipr=9600", ADL_AT_PORT_TYPE(ADL_PORT_UART1, FALSE), NULL, NULL);
s32 uart1_open( eUartRate_t speed )
s32 handle;
sUartSettings_t Settings;
psGItfCont_t pinterface;
sUartEvent_t events;
sUartLc_t lc;
sUartFlowCtrl_t Fc;
/* Device */
Settings.identity = "UART1";
Settings.role = UART_ROLE_NM;
/* Events */
events.user_data = (void*)0;
events.valid_cb = UART_CB_ON_TX_COMPLETE|UART_CB_ON_ERROR|UART_CB_ON_SIG_STATE_CHANGE|UART_CB_ON_RX_COMPLETE;//UART_CB_ON_ALL;
memcpy((u8*)events.cb_list, (u8*)uart1CbTab, 6*sizeof(sGCbDesc_t));
Settings.event_handlers = &events;
Settings.capabilities = NULL;
/* To retrieve the UART SP Interface */
Settings.interface = &pinterface;
/* Line Coding */
lc.op = G_IOC_OP_SET;
lc.valid_fields = UART_LC_ALL;
lc.rate = speed;
lc.stop = UART_STOP_BIT_1;
lc.parity = UART_PARITY_NONE;
lc.data = UART_DATALENGTH_8;
Settings.line_coding = &lc;
/* open UART device */
handle = adl_OpenDevice( DF_UART_CLID, &Settings);
if( handle > 0 )
/* Locally store the uart1 interface */
uart_itf = *pinterface;
uart_if = pinterface;
/* Flow control IO control setting */
Fc.op = G_IOC_OP_SET;
Fc.type = UART_FC_NONE;
if( uart_itf.io_control( handle, IOC_UART_FC, (void*) &Fc) )
uart_itf.close( handle );
handle = 0;
return handle;
//Init_uDrive_uSD_G1();
uart1_hdl = uart1_open(UART_RATE_9600);
if (uart1_hdl == 0)
return;
else
eChStatus_t res;
ascii * cmd = "U";
res = uart_itf.write(uart1_hdl, cmd, 1);
//res = uart_if->write(uart1_hdl, cmd, 1);
if (res == CH_STATUS_NORMAL)
// OK
else if (res == CH_STATUS_ERROR)
The code
works well returning a valid handle, so the UART1 is open. But when i try to write anything with
or with
the module resets itself.
I’ve tried also to set
Settings.event_handlers = NULL;
without success.
Any suggestion ?
Thanks a lot.
