Hi guys,
I’ve found the forum really useful as I don’t have any experience using UARTs and the FCM is very confusing for me. The following code runs fine in ‘Debug’ mode on the Q2406B:
#include "adl_global.h"
/* Mandatory variables */
/* wm_apmCustomStack */
/* wm_apmCustomStackSize */
u32 wm_apmCustomStack [ 256 ];
const u16 wm_apmCustomStackSize = sizeof ( wm_apmCustomStack );
/* Local variables */
s8 UART1_Handle;
ascii msg_test[20];
u16 msg_length;
/* Local functions */
bool hnd_fcmData_U1 ( u16 DataSize, u8 * Data );
bool hnd_fcmCtrl_U1 ( adl_fcmEvent_e Event );
void UART1_Enable(void);
void hnd_tmrMessage_U1 ( u8 ID );
adl_atSendResponse ( ADL_AT_UNS, "\r\n>> hnd_fcmData_U1\r\n");
return TRUE;
adl_atSendResponse ( ADL_AT_UNS, "\r\n>> hnd_fcmCtrl_U1:");
switch (Event)
case ADL_FCM_EVENT_FLOW_OPENNED :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_FLOW_OPENNED\r\n");
adl_fcmSwitchV24State(UART1_Handle, ADL_FCM_V24_STATE_DATA);
break;
case ADL_FCM_EVENT_FLOW_CLOSED :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_FLOW_CLOSED\r\n");
break;
case ADL_FCM_EVENT_V24_DATA_MODE :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_V24_DATA_MODE\r\n");
adl_tmrSubscribe ( TRUE, 10, ADL_TMR_TYPE_100MS, hnd_tmrMessage_U1 );
break;
case ADL_FCM_EVENT_V24_DATA_MODE_EXT :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_V24_DATA_MODE_EXT\r\n");
break;
case ADL_FCM_EVENT_V24_AT_MODE :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_V24_AT_MODE\r\n");
adl_fcmSendData(UART1_Handle, "AT Mode\r\n", 9);
break;
case ADL_FCM_EVENT_V24_AT_MODE_EXT :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_V24_AT_MODE_EXT\r\n");
break;
case ADL_FCM_EVENT_RESUME :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_RESUME\r\n");
break;
case ADL_FCM_EVENT_MEM_RELEASE :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_MEM_RELEASE\r\n");
break;
case ADL_FCM_EVENT_V24_DATA_MODE_FROM_CALL :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_V24_DATA_MODE_FROM_CALL\r\n");
break;
case ADL_FCM_EVENT_V24_AT_MODE_FROM_CALL :
adl_atSendResponse ( ADL_AT_UNS, " ADL_FCM_EVENT_V24_AT_MODE_FROM_CALL\r\n");
break;
return TRUE;
adl_atSendResponse ( ADL_AT_UNS, "\r\n>> UART1_Enable\r\n");
UART1_Handle = adl_fcmSubscribe ( ADL_FCM_FLOW_V24_UART1, hnd_fcmCtrl_U1, hnd_fcmData_U1);
wm_sprintf(msg_test, "\r\nTest Message on UART 1\r\n");
msg_length = wm_strlen(msg_test);
adl_fcmSendData(UART1_Handle, msg_test, msg_length);
adl_atSendResponse ( ADL_AT_UNS, "\r\n>> hnd_tmrMessage_U1 \r\n" );
/* Function : adl_main */
/* Object : Customer application initialisation */
/* Variable Name |IN |OUT|GLB| Utilisation */
/* InitType | | | | Application start mode reason */
adl_atSendResponse ( ADL_AT_UNS, "\r\n>> Start Rev1.0.1 \r\n" );
// TO DO : Add your initialization code here
UART1_Enable();
However, when I compile the Wimo Target mode and program the *.dwl onto the Q2406B, it outputs the following:
>> hnd_fcmCtrl_U1: ADL_FCM_EVENT_FLOW_OPENNED
The program then hangs and eventually the modem resets itself. It seems that the line
is not executing correctly, as the ADL_FCM_EVENT_V24_DATA_MODE state is never reached. Does anyone have any ideas why?
