It looks the sdk is a Linux stuff. So how can I use it under Linux, or Can I get a lib for Linux? I have an arm7 cross compiler (gcc) I have the .a files (from the .lib) but it doesn’t work I have compiler error about the lib. Which compiler was used when this wmlib and adllib had compiled?
Hi ybdragon, which version ot ARM compiler for Linux you are using ? Can You share a litle info with us ? I’ve tryed a several ones with your Makefile , with my own and with wmmake and Wacecom’s *.mak files. Every time compilation fail on linking stage.
