in case of open port in the Target Management perspective I receive an error message that “Bootloader Mode” is active:
This is the text in the detail dialog box:
Open and load local port ttyS0 => ERROR: Connected module seems to be blocked in bootloader mode
Open and load physical port ttyS0 => ERROR: Connected module seems to be blocked in bootloader mode
Open port ttyS0 => DONE: Port opened
Load informations from target => ERROR: Connected module seems to be blocked in bootloader mode
Waiting for module detection => DONE: Target detected sn:null baudrate:115200
Switch to Development mode and check => ERROR: Connected module seems to be blocked in bootloader mode
Switch to Development mode and check => ERROR: An error ocurred during HAPC AT test
Switch to Development mode => DONE: Success
Pause : 300 milliseconds => DONE: Success
Check dev mode unlocked => ERROR: An error ocurred during HAPC AT test
Try to unlock developement mode and check => ERROR: Connected module seems to be blocked in bootloader mode
Waiting for module detection => NO NEED TO DO IT: Success
Check if the target is stuck in bootloader mode => ERROR: Connected module seems to be blocked in bootloader mode
Here is what I see on the AT command interface:
----------------- Port opened -----------------
AT
AT+WMSN
ERROR
AT+CFUN=1
AT
AT+WMSN
ERROR
atat
atat
atat
!RSSI: 94
!RSSI: 88
!RSSI: 94
I have updated my Developer Studio to the latest version 3.2
My EvalBoard is AR7554 and these are the Firmware version infos.
What does this mean?
Br,
Martin…
