I am occasionally seeing all USB devices attached via the HSIC to USB chip disappear on the WP7702. I am not sure if it is the HSIC/USB chip or the on-system HSIC bus itself. Soft reboots do not resolve the issue, only a hard reboot does. I noticed that there are ssmem region errors in the bootloader messages when this issue is occuring. Can you please explain what the ssmem is and what these errors could indicate?
--- ./trim_yes.txt 2024-10-24 14:24:57.672495243 -0400
+++ ./trim_no.txt 2024-10-24 14:24:45.951771365 -0400
@@ -33,6 +33,9 @@
Invalid PMIC gpio 3
Failed to configure/read HW ID minor bit 0
hw_family:5, hw_type:22, hw_rev:40
+ssmem region 2 crc check failed:662ae169 != 642ae169
+SSMEM cannot get allocation table
+SSMEM bad, reinit
SSMEM init OK
DEBUG OU: 0000000000000002
DEBUG OU - setting: 2
@@ -48,6 +51,7 @@
Failed to read size: /swinv/item_files/FOTA_PARTITION
Failed to read size: /swinv/item_files/CUST_IM_CONFIG
flags: u=1 e=1 obmsk=c,0
+ssmem_get: region 21 not exists
ssmem_release: region 20 not exists
ssmem_get: region 20 not exists
Image Load, Start
