I am using Sierra Wireless Fastrack XTend programmable Gateway (FXT009) to send data to web periodically.
I am facing an issue where i am not able to reconnect the TCP Connection whenever the socket connection closes down. I have observed that sometimes the connection closes down automatically after it is opened. Once it is closed, I am not able to reopen it successfully as the WIP Event Handler function is not getting invoked.
Here is the snippet of code that I am using
Firstly I am setting up the TCP Connection under Main() as below. I want to write some data later when the need arises based on some field operations.
bool ChannelStatus = FALSE; // To see status of the socket connection
void main_task(void)
// TCP Initialisation Action Starts by initialising the NET stack
ret = wip_netInit();
if (OK == ret)
TRACE((GW_TCPTASK_TRACEID, "wip_netInit() Successful!"));
CfgGprs(AppliEntryPoint);
The above initialization part is as taken from one of the samples from Developer Studio
Under AppliEntryPoint function as below,
void AppliEntryPoint(void)
socket = wip_TCPClientCreate(TCP_PEER_STRADDR, TCP_PEER_PORT, cbevh, NULL);
if(socket != NULL)
SocketRetries = 0;
TRACE((NORMAL_TRACE_LEVEL, "[AppliEntryPoint] Socket Connection Successful!"));
I get all the right messages as below.
TRACE((NORMAL_TRACE_LEVEL, “[AppliEntryPoint] Socket Connection Successful!”));
The wip_eventHandler_f function is also successfully invoked as seen in the code snippet below
static void cbevh (wip_event_t *ev, void *ctx)
// Go to different routines based on WIP Events
switch(ev->kind)
case WIP_CEV_OPEN:
TRACE((NORMAL_TRACE_LEVEL, "[WIP Event Handler] Connection established successfully"));
ChannelStatus = TRUE;
break;
case WIP_CEV_WRITE:
break;
case WIP_CEV_READ:
break;
case WIP_CEV_ERROR:
TRACE((ERROR_TRACE_LEVEL, "[WIP Event Handler] Error %i on socket! So Closing...", ev-content.error.errnum));
wip_close(ev->channel);
break;
case WIP_CEV_PEER_CLOSE:
TRACE ((NORMAL_TRACE_LEVEL, "[WIP Event Handler] Connection will be closed by peer now..."));
break;
TRACE((NORMAL_TRACE_LEVEL, “[WIP Event Handler] Connection established successfully”));
Now I can write the data successfully and Read the Response as well. The Socket Connection then closes.
The real issue is when I have to send the data again. I am not able to reopen it successfully as the WIP Event Handler function is not getting invoked at all.
I am using the function as below to recreate the connection when the need to send data to web again:
void SendWebPacket(void)
if(ChannelStatus != TRUE)
AppliEntryPoint();
else
TRACE((NORMAL_TRACE_LEVEL, "TCP Connection already exists..."));
write = wip_write(socket, TCPGatewayByteStream, sizeof(TCPGatewayByteStream));
I am able to get into AppliEntryPoint function, I get all the right messages as below.
But the wip_eventHandler_f function is not invoked.
Any help on this is appreciated.
Sathya
