Hi all,
I run into a problem that i need your help. My application gets data via UART port and sends it to a remote server via GPRS. The flow of GPRS is as below:
_ At startup, wait for ADL_SIM_EVENT_FULL_INIT
_ Wait for creg of 1 or 5
_ Initiate bearer, wait for WIP_BEV_IP_CONNECTED
_ Open a socket (wip_TCPClientCreate).
_ Then keep the connection so that modem can send data at anytime
Everything is fine if no error event happens. When the event of WIP_BEV_IP_DISCONNECTED, then WIP_BEV_CTX_DEACT happens, i stop then close the bearer. After 1 minute, i reconnect the bearer but it always fails.
Whenever i initiate bearer again (wip_bearerOpen, wip_bearerSetOpts, wip_bearerStart), no WIP_BEV_IP_CONNECTED event is raised as expected. Instead, WIP_BEV_CONN_FAILED and WIP_BEV_STOPPED events happen . Whenever WIP_BEV_STOPPED is raised, i initiate bearer again, results in a forever loop.
Even though i restart modem with AT+CFUN=1, the phenomenon still remains (creg already returned 1).
I’m using SL6087, firmware 7.51. If anyone has encountered this issue, pls give me an advice.
Thanks & Regrads,
Pham Viet Sam
