I have a MC7304 upgraded to SWI9X15C_05.05.58.00_GENEU-4G_005.029_000. And after upgrade, no serial ports show up neither on Windows nor on Linux.
On Windows, I’ve tried different driver versions. Namely v4773, v4277, v4431 and v4743. It does show up as Mobile Broadband Device, but nothing else.
Linux behaves similarly.
Here’s output of dmesg, after inserting the device:
[73756.008036] usb 1-1: new high-speed USB device number 4 using ehci-pci
[73756.122839] usb 1-1: config 1 has an invalid interface number: 12 but max is 1
[73756.122846] usb 1-1: config 1 has an invalid interface number: 13 but max is 1
[73756.122850] usb 1-1: config 1 has an invalid interface number: 13 but max is 1
[73756.122854] usb 1-1: config 1 has no interface number 0
[73756.122858] usb 1-1: config 1 has no interface number 1
[73756.123593] usb 1-1: New USB device found, idVendor=1199, idProduct=68a2
[73756.123599] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[73756.123604] usb 1-1: Product: MC7304
[73756.123608] usb 1-1: Manufacturer: Sierra Wireless, Incorporated
[73756.125840] cdc_mbim 1-1:1.12: cdc-wdm0: USB WDM device
[73756.126048] cdc_mbim 1-1:1.12 wwan0: register 'cdc_mbim' at usb-0000:00:1d.7-1, CDC MBIM, d2:2b:2f:b5:2d:7f
I’ve tried compiling Gobi drivers, and inserting the modules into kernel to little success.
I’ve tried blacklisting the cmc_mbim, cdc_acm, and cdc_ncm modules, but no driver is loaded for device then.
Windows is 10 1709
Linux kernel is 3.10.0-229.14.1.el7.x86_64
What am I doing wrong?
PS
Here’s also output of lsusb -v, regarding the device:
Bus 001 Device 006: ID 1199:68a2 Sierra Wireless, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1199 Sierra Wireless, Inc.
idProduct 0x68a2
bcdDevice 0.06
iManufacturer 1 Sierra Wireless, Incorporated
iProduct 2 MC7304
iSerial 3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 95
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 12
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 14
bFunctionProtocol 0
iFunction 0
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 12
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 14
bInterfaceProtocol 0
iInterface 0
CDC Header:
bcdCDC 1.10
CDC Union:
bMasterInterface 12
bSlaveInterface 13
CDC MBIM:
bcdMBIMVersion 1.00
wMaxControlMessage 4096
bNumberFilters 32
bMaxFilterSize 128
wMaxSegmentSize 1430
bmNetworkCapabilities 0x20
8-byte ntb input size
UNRECOGNIZED CDC: 08 24 1c 00 01 40 dc 05
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 9
bLength 9
bDescriptorType 4
bInterfaceNumber 13
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
bInterfaceProtocol 2
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 13
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
