No communication with BC127 Development board
I’m not able to communicate in the CMD mode with just purchased BC127 Development Kit.
I’m using CoolTerm. I get an error message “ERROR 100” I’ve also got an “error 0x003” when trying to use the Arduino serial port monitor.
I wish to change the settings so it is a source device and will communicate via HFP and HSP to a bluetooth earbud in sink mode.
I think I am to use the USB UART connector.
I’ve tried using Mac OS High Sierra and Windows 10 with CoolTerm. Got closer with the Mac. I’m really new to the Bluetooth world. I looked at the port permissions. They are wide open at chmod 666. I seem stuck as to what is going on. Using 9600-8-1 CR only.
Thanks!
Partially solved problem. There are 3 different usb connections the board outputs. the usb spp1 and usb spp2 ports to not work. I had to use usbserial xxxxx. Poor documentation…
@BartWalker,
Not sure what ‘documentation’ you are looking at but the discovery user guide is pretty clear about howto use it.
https://source.sierrawireless.com/~/media/support_downloads/airprime/hardware_specs_user_guides/41110821%20bc127%20discovery%20board%20bc127diskit001r1.ashx
Hi Mike,
Thanks for answering. I did have the documentation you suggested. I just did a search on the document you sent. There are two references to SPP neither one goes into any detail. It just says when you connect to SPP. As a newbie, that’s not enough detail to show me how to connect to get into the command mode. Especially when I connected to SPP and did not know enough that that was the wrong connection to use. I think the document was written for people with tribal knowledge and could be improved.
