I’m new to this whole game, but I’ve done C\C++ development before. I’m awaiting the arrival of my device (the Fastrack Supreme 20) and am currently designing some software for it. I came across a document that said that LUA couldn’t do file I/O because it has no file structure (luaw-refman.pdf p.12) and I was hoping to confirm this wasn’t the case when using a C\C++ compiled program. So I wanted to ask if file I/O is possible, and if it is an API call or standard C calls. If it’s API some example code would be appreciated.
The other question I had, seeing as how I’m eager to get started and waiting for my device, is whether an emulator exists for the devices/OS. I know there is a terminal emulator. I’m able to compile the example programs, but have been unable to test them. My understanding from what I’ve read thus far is I need to transfer the program to the device and use remote monitoring tools to debug the program. Again any help/clarification would be appreciated.
I am not familiar with what a Flash Object is or how it would differ from a file.
What I’m planning having is a configuration file, containing an unspecified number of strings and numbers, but the program needs to be able to edit its own configuration file.
Thank you.
And just to confirm… As of yet, there is no software that emulates these devices?
And the only way of debugging a new program is with the device connected to the pc using the remote monitoring applications.
The remote execution is already a kind of emulation of the OAT application for OAT debugging on the PC. Emulating the whole module (software/hardware)? What is the point? At the end you would have to test again everything in the final hardware. I mean it’s not a billion dollar airplane, which is cheaper to simulate in software before production.
