New feature: Go To Declaration *and* Go To Definition
Split-out as a separate thread from viewtopic.php?f=78&t=3613&p=14062#p14062
OK - here it is!
I’ll try it again, but I don’t think that works. It certainly isn’t as clear & straightforward as the previous IDE!
Note that I’m using the terms in the strict ‘C’ meaning:
  • The definition of a function is the place that contains the body of the function; the executable code - its “implemnentation”, if you like;
  • A declaration of a function is a prototype; eg, in a header file.
Similarly, “variables” must have a definition - that’s the place that actually causese memory to be “consumed” - and may also have ‘extern’ declarations .
It’s the declarations in the above sense that seem to be missing from M2MStudio (and are inappropriately called “declarations”)
Thanks for the definition of definition (and declaration) :wink:
So to look for the declaration of a function in the workspace, you also have the Ctrl+G shortcut.
Please let us know if you find this easy enough…
