Still no. No SSH, it still asks for the root password.
I have discovered, that when I’m trying to downgrade to R11 firmware (FX30_WP77xx_full_R11.0.0.007-generic-SWI9X06Y_02.16.06.00.cwe)
the result is
AT!BCFWUPDATESTATUS
!BCFWUPDATESTATUS: FAILED, error code: 80000086
ERROR=Flash write failed: Package not compatible (0X86),STATUS=FAIL
Could you please explain why?
The R15 -
FX30_WP77xx_full_R15.1.0.004-generic-SWI9X06Y_02.36.08.09.cwe
downloaded from the same page here -
https://source.sierrawireless.com/resources/airlink/software_downloads/fx30-firmware/fx30-firmware-catm/#sthash.uuRYTp3A.dpbs
can be flashed successuflly.
jyijyi
September 23, 2024, 3:40am
22
it might be because your module is using new memory.
Only the new FW can be downloaded to new memory.
you can check this by:
AT!entercnd="A710"
AT!BSINFO
This is the output of “BSINFO” command:
AT!BSINFO
Product: FX30(WP7702)
Revision: 40
Main: MDM9206 (000)
Radio: WTR2965
Power: PMD9607 (002)
Flash: MT29F4G08ABBFA3W 512MB x8 (44/0/0) (2048 blocks of 64 pages/block 4096B page size)
jyijyi
September 23, 2024, 1:38pm
24
yes, this is using new memory
I have doubt that my modem was properly reflashed at all.
It has always reported same package version as following:
AT!PACKAGE?
1104770_9910239_FX30(WP7702)_02.36.06.00_00_FX30-Series_001.002_000
even after swiflash’ing it with
So, I have used command “AT!IMAGE” to deleted all firmware images, so it reported all slots empty:
FW 1 EMPTY 0 0 0
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
Max FW images: 3
Active FW image is at slot 255
and then swiflash following firmware:
After swiflash successfully completed, the firmware is not listed among firmware images:
AT!BCFWUPDATESTATUS
!BCFWUPDATESTATUS: SUCCESS
AT!IMAGE?
FW 1 EMPTY 0 0 0
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
Max FW images: 3
AT!PACKAGE?
Do you have any ideas why it is not properly reflashed?
jyijyi
September 25, 2024, 2:59pm
26
how about ati3 and ati8?
do they get updated?
what do you mean by ati3/ati8 and how to check it?
jyijyi
September 25, 2024, 3:27pm
28
these are AT commands, you can enter it in modem port
ATI3
Model: FX30(WP7702)
Revision: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
IMEI: 354723094588646
IMEI SV: 6
FSN: AT209750080210
+GCAP: +CGSM
ATI8
Legato Ver: 21.05.0.54b96444_0a6e18078edde5151619cb964564694d
Yocto Ver: SWI9X06Y_03.00.13.00 2022-12-27_09:10:00
OS Ver: Linux version 4.14.253 (oe-user@oe-host) ( gcc version 9.3.0 (GCC), GNU ld (GNU Binutils) 2.34.0.20200220) #1 PREEMPT Tue Dec 27 08:09:00 UTC 2022
LK Ver: SWI9X06Y_03.00.13.00
RootFS Ver: SWI9X06Y_03.00.13.00 2022-12-27_09:10:00
UserFS Ver: unknown
MCU Ver: 002.015
jyijyi
September 26, 2024, 1:44pm
30
According to the release note, you should use fwupdate command to upgrade firmware
just to summarize, if I cannot reset root password then I cannot update the modem, is that correct?
jyijyi
September 26, 2024, 2:41pm
32
I can see the yocto and legato are updated
You can try using fdt tool in windows
