What do you mean by “can only send my array data, the data from com1 cannot be send”.
If you are subscribing COM1 using FCM service then it is possible that data coming from COM1 can be stored and send to some other port (or something like that).
So, can you please explain what exactly you are doing in your application. what are the events received in your application using FCM service.
After opening the FCM, is FCM close event received immediately, without receiving data from COM 1?What is the exact scenario?
Can you please check in your application that when are you unsubscribing FCM service because FCM CLOSE event is related to adl_fcmUnsubscribe().
