See: viewtopic.php?f=78&t=3466&p=13145#p13145
So, it is possible to spread views over multiple monitors?
I had a try, but it didn’t seem to want to let me drag a view outside of the Eclipse window… ![]()
You can instantiate a new Eclipse window with… Window > New window ![]()
Would that actually work - or would they just “fight”…? ![]()
Ooops… I took the try, and they actually just fight ![]()
Last tip: you can detach a view (right click on the view tab > Detached)
It doesn’t allow you to switch between the windows by Alt+Tab since it is still the same application, but maybe you should be able to put the detached view on the secondary monitor…
That’d be fine - I’ll give it a try…
Yes, it lets you put the views on the other monitor ![]()
You have to do each one individually - Traces and Console view. ![]()
But, when you try to switch the “main” screen back to the Open-AT perspective - to see the sources - the Traces and Console views disappear! ![]()
So that’s useless! ![]()
However, I’ve just found that TMT (and TE) will happily share the serial link with M2MStudio - so, apart from the ‘Download’ button, I don’t need the (inferior) M2MStudio Target Management perspective at all ![]()
I can use M2MStudio just for editing & building on one screen, and have TMT (and TE) for target debug on the other. ![]()
that’s SeLiMa for you ![]()
