I used the ode as follows to send SMS continuously to a mobile no, But i got only the first sms " HELLO WORLD!", only the next SMS i was not received?
Is it must to wait for +WIND:4 response
void main_task ( void )
adl_InitType_e adlInitType = adl_InitGetType ();
/* SMS automaton test application */
TRACE ( ( SA_TRACE_LEVEL, "SMS automaton sample main" ) );
TRACE ( ( SA_TRACE_LEVEL, __DATE__ ) );
TRACE ( ( SA_TRACE_LEVEL, __TIME__ ) );
TRACE ( ( SA_TRACE_LEVEL, "Start SMS_Automaton application" ) );
/* Subscribe to the SMS Service */
SmsAutoHandle = adl_smsSubscribe ( cbSmsAutoHandler, cbSmsAutoCtrlHandler,
ADL_SMS_MODE_TEXT );
TRACE ( ( SA_TRACE_LEVEL, "adl_smsSubscribe : "
"SmsAutoHandle %d", SmsAutoHandle ) );
adl_atUnSoSubscribe("+WIND: 4",wind_4_handler);
bool wind_4_handler(adl_atUnsolicited_t * paras)
s8 sRet=0,var1=0,var2=0;
TRACE((1,"Inside wind 4 handler"));
/* Use adl_smsSend () function to send SMS*/
var1++;
if(var1==1){
sRet = adl_smsSend(SmsAutoHandle, "9092363289", "Hello World!", ADL_SMS_MODE_TEXT);
var2++;
if(var2==1){
sRet = adl_smsSend(SmsAutoHandle, "9092363289", "check sms send", ADL_SMS_MODE_TEXT);
return (0);
Can anyone help me
thanks in advance
You need to wait for the first SMS to be sent before sending the second. You can’t just look at the return value of adl_smsSend, you must look at the SMS control callback function you specified in your subscription to the SMS service. Only once you get a SMS successfully sent in the callback handler can you send the next SMS.
See this thread for a detailed explanatition: [url]https://forum.sierrawireless.com/t/error-sending-more-than-one-sms/3151/1]
Based on your reply i implemented the adl wait evenat as follows for that i got watchdog reset,
so can you explain me in my code which place i need to correct?
static u32 l_u32_MyEvent = NULL;
l_u32_MyEvent = adl_eventCreate(0);
var1++;
if(var1==1){
TRACE((1,"var1=%d",var1));
while(1)
adl_eventWait(l_u32_MyEvent,1,NULL, ADL_EVENT_WAIT_ANY, ADL_EVENT_NO_TIMEOUT);
adl_eventClear(l_u32_MyEvent,1,NULL);
var2++;
if(var2==1){
TRACE((1,"var2=%d",var2));
return (0);
the adl_eventWait calls i referred ADL used guide only
I think you didn’t read the whole post that was provided previously. Study that post, and also this one:
[url]https://forum.sierrawireless.com/t/delay-function-not-working-as-desired/6240/1]
