cph
March 12, 2011, 6:35am
1
I tried this but it didn’t work.
/* file: main.c */
#include "adl_global.h"
#include "generated.h"
/* variables */
static s8 sms_automaton_Handle_txt;
void SMS_AUTO_ctrl_Handler(u8 Event, u16 Nb)
// Does nothing
bool SMS_AUTO_Handler(ascii *SmsTel, ascii *SmsTimeOrLength, ascii *SmsText)
return FALSE;
void main_task ( void )
// Subscribe to the SMS Service
sms_automaton_Handle_txt = adl_smsSubscribe(SMS_AUTO_Handler, SMS_AUTO_ctrl_Handler, ADL_SMS_MODE_TEXT);
adl_smsSend(sms_automaton_Handle_txt, "+628813227153", "SMS test", ADL_SMS_MODE_TEXT);
awneil
March 12, 2011, 1:27pm
2
Rule 1 in any form of programming:
Never ignore the return values from API calls!
cph
March 13, 2011, 5:24am
3
ok, the adl_smsSubscribe return successfully but the adl_smsSend said that “initialization not yet
performed, or sending an SMS already in progress” (ADL_RET_ERR_BAD_STATE).
what does it mean?
if I should perform some initialization, what initialization should I perform?
is it about mandatory API?
I’ve search about mandatory API chapter but I couldn’t find it.
product is not ready to send an SMS
(initialization not yet performed, or sending an SMS already in
progress)
Here initialization implies GSM network registration . Check you are sending SMS after complete registration of network, also wait until last SMS has been sent.
cph
March 14, 2011, 7:04am
5
manikandan.t:
progress)
by using adl_simSubscribe function?
awneil
March 14, 2011, 2:22pm
6
Study the documentation for the adl_simSubscribe function - does it give you all the information necessary to know when the unit is ready to send an SMS…?
Take a look through the FAQ/Wiki thread - in particular: viewtopic.php?f=7&t=3766&start=15#p17708
cph
March 15, 2011, 5:45am
7
here’s my code at the moment:
/* variables */
switch (Event) {
case ADL_SMS_EVENT_SENDING_ERROR:
adl_atSendResponse(ADL_AT_UNS, "\r\nSMS_AUTO_ctrl_Handler(): ADL_SMS_EVENT_SENDING_ERROR\r\n");
break;
case ADL_SMS_EVENT_SENDING_MR:
adl_atSendResponse(ADL_AT_UNS, "\r\nSMS_AUTO_ctrl_Handler(): ADL_SMS_EVENT_SENDING_MR\r\n");
break;
default:
adl_atSendResponse(ADL_AT_UNS, "\r\nSMS_AUTO_ctrl_Handler(): OK\r\n");
break;
ascii *foo = (ascii*)adl_memGet(50);
if (foo != NULL) {
wm_strcpy(foo, "\r\n");
wm_strcpy(foo, SmsTel);
wm_strcat(foo, " ");
wm_strcat(foo, SmsText);
wm_strcat(foo, "\r\n");
adl_atSendResponse(ADL_AT_UNS, foo);
adl_memRelease(foo);
} else {
adl_atSendResponse(ADL_AT_UNS, "\r\nout of memory.\r\n");
return FALSE;
void sim_Hdlr (u8 ev)
switch (adl_simSubscribe(sim_Hdlr, NULL)) {
case ADL_RET_ERR_SERVICE_LOCKED:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_simSubscribe(): ADL_RET_ERR_SERVICE_LOCKED\r\n");
break;
case ADL_RET_ERR_ALREADY_SUBSCRIBED:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_simSubscribe(): ADL_RET_ERR_ALREADY_SUBSCRIBED\r\n");
break;
case ADL_RET_ERR_PARAM:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_simSubscribe(): ADL_RET_ERR_PARAM\r\n");
break;
default:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_simSubscribe(): OK\r\n");
break;
switch (sms_automaton_Handle_txt) {
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSubscribe(): ADL_RET_ERR_PARAM\r\n");
break;
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSubscribe(): ADL_RET_ERR_SERVICE_LOCKED\r\n");
break;
default:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSubscribe(): OK\r\n");
break;
switch (adl_smsSend(sms_automaton_Handle_txt, "+628813227153", "SMS test", ADL_SMS_MODE_TEXT)) {
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSend(): ADL_RET_ERR_PARAM\r\n");
break;
case ADL_RET_ERR_UNKNOWN_HDL:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSend(): ADL_RET_ERR_UNKNOWN_HDL\r\n");
break;
case ADL_RET_ERR_BAD_STATE:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSend(): ADL_RET_ERR_BAD_STATE\r\n");
break;
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSend(): ADL_RET_ERR_SERVICE_LOCKED\r\n");
break;
default:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_smsSend(): OK\r\n");
break;
and here’s the result:
awneil
March 15, 2011, 6:54am
8
Where in the code do you check to see that the unit is ready to send an SMS
cph
March 15, 2011, 7:07am
9
I have no idea how to do it.
Hi
In your code make sure you wait for the specific +WIND indications before performing your operation.
In this case you need to wait for +WIND:16 indication(which specifies that SMS and SMS CB services have been initialized).
Paruthiv
awneil
March 16, 2011, 7:32am
11
No - there isn’t a specific +WIND: indication for this.
This is necessary, but not sufficient .
This just indicates that the initialisation is complete on the module - it does not indicate that the module is GSM-Registered!
Again, the OP needs to spend time studying the AT Commands Guide to look at what commands & indications are available.
Specifically, AT+CREG queries the current registration state - and can be used to enable unsolicited indication when the state changes.
So the unit can either use AT+CREG to specifically check - or “poll” - the current registration state, or use the unsolicited notifications to maintain its own record of the state.
The ADL User Guide tells how to issue AT Commands, and how to monitor (or “subscribe” to) unsolicited indications.
cph
March 28, 2011, 5:02am
13
it’s still not working.
here’s my code:
adl_atSendResponse(ADL_AT_UNS, "\r\nSMS_AUTO_ctrl_Handler()\r\n");
switch (Event) {
break;
break;
default:
break;
if (foo != NULL) {
} else {
return FALSE;
bool unso_hdlr (adl_atUnsolicited_t *param)
s8 sms_automaton_Handle_txt = adl_smsSubscribe(SMS_AUTO_Handler, SMS_AUTO_ctrl_Handler, ADL_SMS_MODE_TEXT);
adl_atSendResponse(ADL_AT_UNS, "\r\nunso_hdlr(): OK\r\n");
break;
break;
break;
break;
default:
break;
return(TRUE);
// TODO Insert your task initialization code here
switch (adl_atUnSoSubscribe("+CREG: 1", unso_hdlr)) {
case OK:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_atUnSoSubscribe(): OK\r\n");
break;
case ERROR:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_atUnSoSubscribe(): ERROR\r\n");
break;
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_atUnSoSubscribe(): ADL_RET_ERR_SERVICE_LOCKED\r\n");
break;
default:
adl_atSendResponse(ADL_AT_UNS, "\r\nadl_atUnSoSubscribe(): unknown error\r\n");
break;
any suggestion?
Have you worked through the SW example code?
awneil
March 28, 2011, 9:33am
15
cph:
here’s the result
Really?
What you showed there doesn’t match the code that you posted - does it?
And what did I say about ignoring the return values from API calls…?
cph
March 28, 2011, 2:47pm
16
the example is for incoming sms
I entered the command “AT+CREG=1” manually if that’s what you mean.
if I had to conclude what to do (the steps) to send a single sms after reading some hundreds of pages of a manual (or two), well I have to admit that I’m not that smart sir.
awneil
March 29, 2011, 7:06am
17
This is the output that you showed:
This is the start of the code that you showed:
switch( adl_atUnSoSubscribe("+CREG: 1", unso_hdlr) ) {
case OK:
adl_atSendResponse( ADL_AT_UNS,
break;
case ERROR:
break;
break;
default:
break;
None of those outputs appears in your picture, so I think it’s fair to say that the picture doesn’t match the code!
In your unso_hdlr , you use the handle value before checking that it is valid:
bool unso_hdlr( adl_atUnsolicited_t *param )
s8 sms_automaton_Handle_txt = adl_smsSubscribe( SMS_AUTO_Handler,
SMS_AUTO_ctrl_Handler, ADL_SMS_MODE_TEXT );
adl_atSendResponse( ADL_AT_UNS, "\r\nunso_hdlr(): OK\r\n" );
switch
adl_smsSend
sms_automaton_Handle_txt, // you haven't checked this!
"+628813227153",
"SMS test",
ADL_SMS_MODE_TEXT
cph
March 29, 2011, 8:55am
18
awneil:
case OK:
break;
case ERROR:
break;
break;
default:
break;
switch
adl_smsSend
"+628813227153",
"SMS test",
ADL_SMS_MODE_TEXT
never mind, I finally figure it out. but thanks anyway.
I just wish there are some tutorials for a non-scientist person like me.
awneil
March 29, 2011, 11:39am
19
So how about you conclude this thread by explaining what you did to get it going?
That would benefit the next “non-scientist” to come along with the same question.
But what is it that you think is so “scientific” about this?
Programming is , in its very nature, a discipline that requires careful analysis, design and attention to detail. Not everyone is cut out to be a programmer…
