any idea what could be the problem ther? At the previouse step I have created some apps. Now I want to combine those apps in a system. But after excecuting the mksys command, I get following error:
mksys -t wp76xx --output-dir=_build_edgeSDK _system/edgeSDKSystem.sdef
Putting child 0x55c8c3ef3e20 (system) PID 31832 on the chain.
Live child 0x55c8c3ef3e20 (system) PID 31832
** WARNING: File system size limit being ignored for unsandboxed application 'tmCore'.
ninja: error: '/home/pf/Documents/myWorkspace/leaf-data/wp76/wp76-legato/build/wp76xx/framework/md5', needed by '/home/pf/Documents/myWorkspace/edgeSDK/_build_edgeSDKSystem/wp76xx/staging/info.properties', missing and no known rule to make it
Reaping losing child 0x55c8c3ef3e20 PID 31832
Makefile:52: recipe for target 'system' failed
make: *** [system] Error 1
Removing child 0x55c8c3ef3e20 PID 31832 from chain.
(lsh:wp76) pf@Ubuntu18:~/Documents/myWorkspace/edgeSDK$
so I run the “make wp76xx” in leaf shell now, but I still get some errors:
(lsh:wp76) pf@Ubuntu18:~/Documents/myWorkspace/leaf-data/wp76/wp76-legato$ make wp76xx
Building Legato for target 'wp76xx'
modules/WiFi/moduleDefs:12: Legato WiFi version is undefined...
GEN version
MAKE tools
make[1]: Entering directory '/home/pf/.leaf/wp76-legato_20.04.0-202004151904'
Using ninja installed at: /usr/bin/ninja
GEN /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/tools/build.ninja
Tools arch: x86_64
MAKE mkPatch
make[2]: Entering directory '/home/pf/.leaf/wp76-legato_20.04.0-202004151904/framework/tools/mkPatch'
make[2]: '/home/pf/.leaf/wp76-legato_20.04.0-202004151904/bin/mkPatch' is up to date.
make[2]: Leaving directory '/home/pf/.leaf/wp76-legato_20.04.0-202004151904/framework/tools/mkPatch'
NINJA /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/tools/build.ninja
ninja: no work to do.
make[1]: Leaving directory '/home/pf/.leaf/wp76-legato_20.04.0-202004151904'
GEN sources.md5
GEN package.properties
MAKE framework
NINJA /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/build.ninja
MKEXE /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/bin/supervisor
[10/10] Linking C executable
MKEXE /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/bin/serviceDirectory
[4/4] Linking C executable
MKEXE /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/bin/logCtrlDaemon
[5/5] Linking C executable
MKEXE /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/bin/configTree
[14/14] Linking C executable
MKEXE /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/bin/watchdog
[7/7] Linking C executable
MKEXE /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/bin/updateDaemon
[16/16] Linking C executable
MAKE targetTools
make[2]: Entering directory '/home/pf/.leaf/wp76-legato_20.04.0-202004151904'
CMAKE /home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/lib/libjansson.so
Makefile.targetTools:107: recipe for target '/home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/lib/libjansson.so' failed
make[2]: *** [/home/pf/.leaf/wp76-legato_20.04.0-202004151904/build/wp76xx/framework/lib/libjansson.so] Error 127
make[2]: Leaving directory '/home/pf/.leaf/wp76-legato_20.04.0-202004151904'
Makefile.framework:249: recipe for target 'targetTools' failed
make[1]: *** [targetTools] Error 2
Makefile:535: recipe for target 'framework' failed
make: *** [framework] Error 2
