I am trying to Flash update a working MC7750 Verizon card. When I run the flash update, I get an “unable to read SKU” error and cannot continue. Is there a way to fix this? The aircard otherwise works fine and connects to Verizon. Thanks.
CobbE
Hi, From where you got this FW SKU? is it from source?
Thanks, Alex
The same problem
Win10. Setting up exe to win7 compatibility mode and got or SKU error or timeout for firmware downloading appx at 32%
Hi, could you please explain a bit more about your issue? Also as I asked earlier from where you got the SKU/FW? what is the FW version?
