I have an MC7511 in QMI mode managed by a python script on Linux using libqmi. It is connected to AT&T via an IPv4 PDP session. This is the router and it provides WiFi to local devices where the MTU is set to 1400 (IPv4 only; no IPv6).
A WIndows 10 machine connects to the MC7511 router above via WiFi. A hard crash occurs on the MC7511 when I join a Microsoft Teams call at the Windows 10 machine. By hard crash I mean that data flow immediately ceases at the MC7511 and /dev/ttyUSB2 is no longer responsive; nothing spits out in dmesg.
I’m still trying to characterize but so far this only happens with Microsoft Teams when joining a call. Teams otherwise works OK say for general chat.
I’m running the AT&T image below. Any ideas on what might cause this?
at!entercnd="A710"
at!image?
FW 1 GOOD 10 0 0 ?_? 01.07.02.00_?
FW 2 GOOD 1 0 0 ?_? 01.07.00.00_?
FW 3 GOOD 9 0 0 ?_? 01.08.04.00_?
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.008_004 01.07.02.00_ATT
PRI FF GOOD 0 0 0 002.002_000 01.07.00.00_GENERIC
PRI FF GOOD 0 0 0 002.015_002 01.08.04.00_VERIZON
Max PRI images: 50
at!impref?
!IMPREF:
preferred fw version: 00.00.00.00
preferred carrier name: AUTO-SIM
preferred config name: AUTO-SIM_000.000_000
current fw version: 01.07.02.00
current carrier name: ATT
current config name: ATT_002.008_004
at+cgdcont?
+CGDCONT: 1,"IPV4V6","broadband","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
