MC7455 - unable to clean status reports at "SR"
When the status reports are enabled and they are written into the storage, there is no way for them to be cleared. The capacity of the “SR” memory is probably 30. That means, that after sending 30 SMS messages, the modem is not able to send an SMS message. The memory is cleared only after full reset. We are configuring the reports with “AT+CNMI=1,2,0,1,0”.
Example
at+cpms=“SR”
+CPMS: 10,30,1,2,0,75
AT+CMGD=1,4
at+cpms=“SR”
my test shows that the “SR” value will not go up after sending SMS
at+cnmi=1,2,0,1,0
ati3
Model: MC7455
Revision: SWI9X30C_02.38.00.00 rE3F3E55C03AE94 jenkins 2022/01/13 05:16:00
MEID: 35907206012345
ESN: 12800012345, 80012345
IMEI: 359072060012345
IMEI SV: 22
FSN: LQ530100512345
+GCAP: +CGSM
at+cpms="SR"
+CPMS: 0,30,0,40,0,40
at+cmgs="1234567"
> asdfqwer
+CMGS: 10
at+cpms?
+CPMS: "SR",0,30,"SM",0,40,"SM",0,40
In your example the sms is not actually delivered, and obviously you don’t have delivery report.
+CDSI: “SR”,14
Is an indication that the report is received and stored. We did not find any configuration of “+CNMI” which allows us to receive “+CDS” notifications without storing them
i can receive the SMS, so it should be delivered
For our situation to reproduce you should be able to observe +CDSI: “SR”,14 and +CDS unsolicited result codes in the modem serial interface.
how to observe this +CDSI?
In order to receive sms delivery report, we are sending the sms messages in PDU mode and adding delivery request into the PDU. Additionally, “+CNMI” need to be configured.
This is the excerpt from our log, I hope it will be clear
1705412535.936 D modem.py:send_command : /tmp/modem_04 TX: AT+CMMS=1
1705412535.942 D modem.py:getline : /tmp/modem_04 RX: OK
1705412535.942 I sender.py:set_status : /tmp/modem_04 Changing status READY → TARGET
1705412536.133 D modem.py:getline : /tmp/modem_02 RX: >
1705412536.133 D sender.py:store_sms : 079179520002001121000C91795224467213401002C120
1705412536.159 D modem.py:getline : /tmp/modem_02 RX: +CMGW: 0
1705412536.160 D modem.py:getline : /tmp/modem_02 RX: OK
1705412537.333 D modem.py:send_command : /tmp/modem_02 TX: AT+CMSS=0
1705412537.437 I sender.py:run : /tmp/modem_04 Keeping waiting for send event.
1705412537.660 D modem.py:getline : /tmp/modem_02 RX: +CMSS: 182
1705412537.661 D modem.py:getline : /tmp/modem_02 RX: OK
1705412537.661 I sender.py:send_sms_from_mem : /tmp/modem_02 Sent SMS number 182
1705412537.661 I sender.py:run : /tmp/modem_02 Sending took 0.334 s
1705412537.662 I sender.py:wait_for_delivery_report: /tmp/modem_02 Waiting for delivery report for 10.0 s…
1705412538.355 D modem.py:getline : /tmp/modem_02 RX: +CDSI: “SR”,0
Here is more convenient reproduction of the issue for SMS in text mode. It is possible to observe the +CMGD command does not affect the status report storage
AT+CNMI=1,2,0,1,0
at+cpms=“SR”
+CPMS: 13,30,1,2,0,75
AT+CMGS=“+972525397371”
dd
+CMGS: 44
+CDS: 6,44,“972525397371”,241,“24/01/17,13:46:12+08”,“24/01/17,13:46:32+08”,0
at+cpms=“SR”
+CPMS: 14,30,1,2,0,75
at+cmgd=1,4
at+cpms=“SR”
here is my test on MC7455:
AT+CNMI=1,2,0,1,0
at+cmgs="63919599"
> asdfasdf
+CMGS: 17
+CMT: "+85263919599",,"24/01/17,21:11:53+32"
asdfasdf
at+cpms?
+CPMS: "SR",0,30,"SR",1,75,"SM",2,40
at+cmgd=1,4
at+cpms?
+CPMS: "SR",0,30,"SR",0,75,"SM",2,40
In this example you are receiving “+CMT” unsolicited result code, which is actually a report about incoming SMS message. Our problem is with “+CDS” and “+CDSI” result codes, representing SMS status reports. Probably they are behaving differently.
i cannot generate the “+CDS” and “+CDSI” result codes, any idea?
are you using same FW as mine?
We are trying to upgrade to 02.38.00.00. Hope it will change something. For your tests - sometimes status report comes after 20-30 seconds, may be you need to wait more.
I don’t see the notification:
[2024-01-18 23:50:43.843] at!Gstatus?
[2024-01-18 23:50:47.180] !GSTATUS:
[2024-01-18 23:50:47.180] Current Time:  141		Temperature: 26
[2024-01-18 23:50:47.180] Reset Counter: 1		Mode:        ONLINE
[2024-01-18 23:50:47.180] System mode:   LTE        	PS state:    Attached
[2024-01-18 23:50:47.180] LTE band:      B3     		LTE bw:      20 MHz
[2024-01-18 23:50:47.180] LTE Rx chan:   1400		LTE Tx chan: 19400
[2024-01-18 23:50:47.180] LTE CA state:  INACTIVE    		LTE Scell band:B7
[2024-01-18 23:50:47.180] LTE Scell bw:20 MHz  		LTE Scell chan:3150
[2024-01-18 23:50:47.180] EMM state:     Registered     	Normal Service
[2024-01-18 23:50:47.180] RRC state:     RRC Connected
[2024-01-18 23:50:47.180] IMS reg state: No Srv
[2024-01-18 23:50:47.180] PCC RxM RSSI:  -61		RSRP (dBm):  -94
[2024-01-18 23:50:47.180] PCC RxD RSSI:  -96		RSRP (dBm):  -140
[2024-01-18 23:50:47.180] SCC RxM RSSI:  -85		RSRP (dBm):  -108
[2024-01-18 23:50:47.180] SCC RxD RSSI:  -105		RSRP (dBm):  -134
[2024-01-18 23:50:47.180] Tx Power:      --		TAC:         0652 (1618)
[2024-01-18 23:50:47.180] RSRQ (dB):     -12.7		Cell ID:     01E5110C (31789324)
[2024-01-18 23:50:47.180] SINR (dB):      3.8
[2024-01-18 23:50:47.180] OK
[2024-01-18 23:50:52.997] AT+CNMI=1,2,0,1,0
[2024-01-18 23:50:53.725] OK
[2024-01-18 23:50:54.534] at+cpms?
[2024-01-18 23:50:56.106] +CPMS: "SR",0,30,"SR",0,75,"SR",0,75
[2024-01-18 23:50:56.106] OK
[2024-01-18 23:51:38.041] at+cpms?
[2024-01-18 23:51:40.113] +CPMS: "SR",0,30,"SR",0,75,"SR",0,75
[2024-01-18 23:51:40.113] OK
[2024-01-18 23:52:19.294] at+cmgs="63919599"
[2024-01-18 23:52:22.305] > asdfasdf
[2024-01-18 23:52:24.076]
[2024-01-18 23:52:24.076] +CMGS: 20
[2024-01-18 23:52:24.076] OK
[2024-01-18 23:52:24.298]
[2024-01-18 23:52:24.298] +CMT: "+85263919599",,"24/01/18,23:52:23+32"
[2024-01-18 23:52:24.298] asdfasdf
[2024-01-18 23:52:28.319] at+cpms?
[2024-01-18 23:52:29.801] +CPMS: "SR",0,30,"SR",1,75,"SR",1,75
[2024-01-18 23:52:29.801] OK
[2024-01-18 23:53:51.943] at+cmgd=1,4
[2024-01-18 23:53:54.822] OK
[2024-01-18 23:53:55.615] at+cpms?
[2024-01-18 23:53:56.892] +CPMS: "SR",0,30,"SR",0,75,"SR",0,75
[2024-01-18 23:53:56.892] OK
Hello. We have upgraded to the latest firmware and made more detailed test. Please take a look. Hope it is reproduces in your environment
SMS delivery report minimum example
Connect to modem 4
sudo microcom /dev/ttyUSB29 -s 115200
at+cfun=1,1
ate
ati
Model: MC7455
MEID: 35457251202320
IMEI: 354572512023201
IMEI SV: 22
FSN: LQ231622560310
+GCAP: +CGSM
Enable SMS report and Status report and discard old URC (Error!)
AT+CNMI=0,2,0,1,0
+CMS ERROR: 303
Enable SMS report and Status report and flush URC (Error!)
AT+CNMI=2,2,0,1,0
+CMS ERROR: 303
Enable SMS report and Status report and discard new URC when buffer full (No error, but not what we want!)
AT+CNMI=1,2,0,1,0
Configure first byte of PDU to enable request of delivery report
AT+CSMP=49,
+CMS ERROR: 313
AT+CSMP?
+CSMP: 49,0,0
Check SR memory storage (3 slots of 30 were occupied before!)
AT+CPMS=“SR”
+CPMS: 3,30,1,2,1,2
AT+CPMS?
+CPMS: “SR”,3,30,“SM”,1,2,“SM”,1,2
Send SMS, receive delivery report in +CDS URC
AT+CMGF=1
AT+CSCS=“GSM”
at+cmgs=“+972542642731”
asdasdasd
+CMGS: 4
+CDS: 6,13,“972542642731”,241,“24/01/18,16:31:06+08”,“24/01/18,16:31:07+08”,0
Check SR memory storage (4 slots occupied, even after clearing!)
AT+CPMS?
+CPMS: “SR”,4,30,“SM”,1,2,“SM”,1,2
at+cmgd=1,4
AT+CPMS?
Send 25 more SMS, send the next one
29 slots left, taking the 30th
+CMGS: 45
+CDS: 6,45,“972542642731”,241,“24/01/18,16:37:44+08”,“24/01/18,16:37:46+08”,0
AT+CPMS?
+CPMS: “SR”,30,30,“SM”,1,2,“SM”,1,2
No more CDS will arrive, because SR all slots are occupied
30 SR slots occupied
+CMGS: 46
i don’t see what has been added to generate this notification compared to my log
For text mode, +CSMP command is required. It returns error on the modem, however it is still enables status report for the text mode sms. Please review my session below. First two sms did not receive the status, however the third did
at
AT+CMGF=1
AT+CSCS=“GSM”
a
+CMGS: 74
AT+CPMS=“SR”
+CPMS: 0,30,1,2,1,2
AT+CNMI=1,2,0,1,0
b
+CMGS: 75
AT+CSMP=49,
+CMS ERROR: 313
AT+CNMI?
+CNMI: 1,2,0,1,0
AT+CSMP?
+CSMP: 49,0,0
c
+CMGS: 76
+CDS: 6,76,“972542642731”,241,“24/01/19,09:27:30+08”,“24/01/19,09:27:31+08”,0
no +CDS is observed, could this be related to network operator?
ati3
Model: MC7455
MEID: 35907206012435
ESN: 12800001232, 80001234
IMEI SV: 22
FSN: LQ530100512345
+GCAP: +CGSM
at+cmgf=1
aat
at+cscs?
+CSCS: "IRA"
at+cscs="GSM"
at+cpms?
+CPMS: "SM",2,40,"SM",2,40,"MT",0,255
at+cpms="SR"
+CPMS: 0,30,2,40,0,255
at+cnmi=1,2,0,1,0
at+csmp?
+CSMP: ,,0,0
at+csmp=49,0,0
at+cmgs="1234567"
> asdfadf
+CMGS: 21
at+csmp?
+CSMP: 49,0,0,0
AT+CSMP=49,
at+cmgs="1234567"
> asdfasdf
+CMGS: 22
May be try with actual phone number and make sure the sms is actually delivered. Otherwise, yes it may be the operator
yes, it is actual phone number and i can receive the sms in my phone, i just modify the log
I have tried another SIM with another operator, the result is the same:
at!gstatus?
!GSTATUS:
Current Time:  52               Temperature: 26
LTE band:      B5               LTE bw:      10 MHz
LTE Rx chan:   2460             LTE Tx chan: 20460
LTE CA state:  NOT ASSIGNED
PCC RxM RSSI:  -59              RSRP (dBm):  -86
PCC RxD RSSI:  -100             RSRP (dBm):  -140
Tx Power:      --               TAC:         2775 (10101)
RSRQ (dB):     -10.8            Cell ID:     016E8A49 (24021577)
SINR (dB):      6.8
at+csmp?
+CSMP: ,,0,0
at+cmgf=1
at+cscs?
+CSCS: "IRA"
at+cscs="GSM"
at+cpms="SR"
+CPMS: 0,30,39,80,0,75
at+cnmi=1,2,0,1,0
at+csmp=49,0,0
at+cmgs="1234567"
> asdfasdf
+CMGS: 37
at+cpms?
+CPMS: "SR",0,30,"SM",39,80,"SR",0,75
I wonder how “1234567” may be the actual phone number
