I have a mc7455 connected to a mikrotik board which doesn’t support usb 3.0 and therefor I use the at!usbspeed=0 command to set it as usb 2.0 only.
If I don’t do this it won’t be recognized by the router.
I tried moving to Verizon FW on the device that didn’t support this command and had to tapeout the pins in order to upgrade the FW but then I had to reapply the command to enable usb2.
My question is, if I had done a FOTA upgrade to the old Verizon FW instead of moving to it would it keep the usb2 setting?
Just to clarify the order of actions I want to do:
Have a device running latest generic and usb2 mode set by at command
Preform FOTA upgrade of old Verizon FW(upgrade to same version as generic) , causing a switch to Verizon FW and restart
Now would I get the device running latest Verizon FW and usb2?
Please try to upgrade to the latest SWI9X30C_02.33.03.00_00_VERIZON firmware and try again. I can set at! usbspeed=0 on firmware SWI9X30C_02.33.03.00_00_VERIZON.
You can get it here AirPrime EM/MC74xx Approved FW Packages
Help to tick “Solutions” if your question is answered.
I try on my MC7455 module. The at!usbspeed=0 is not persistent when switching to Verizon firmware. It also is not persistent when performing the FOTA upgrade of Verizon firmware.
According to my testing if you set the NV item which sets the speed then it does hold the value as per the below.
at!entercnd="A710"
at!usbspeed?
SUPPORTED:Super-Speed
CURRENT :High-Speed
at!usbspeed=0
at!reset //Reset for the change to take effect
at
ati
Model: MC7455
Revision: SWI9X30C_02.36.00.00 r8395 CARMD-EV-FRMWR2 2020/10/28 06:33:51
MEID: 35907206005151
IMEI: 359072060051519
IMEI SV: 22
FSN: LQ545100810110
+GCAP: +CGSM
at!entercnd="A710"
at!usbspeed?
SUPPORTED:High-Speed
CURRENT :High-Speed
at //Downgraded firmware here
ati
Model: MC7455
Revision: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30
IMEI SV: 20
FSN: LQ545100810110
+GCAP: +CGSM
at!entercnd="A710"
at!usbspeed?
CURRENT :High-Speed //Setting has been maintained
What I haven’t done is test it with a firmware where the command does not exist to check the NV item but I can’t see a reason if you set the speed with a firmware version that can set it, why it would be reset if you downgraded, you just would not be able to set it to anything else unless you upgraded it. Clear?
