Ok, I installed GobiNet and GobiSerial from https://source.sierrawireless.com/resources/airprime/software/usb-drivers-linux-qmi-software-s2,-d-,36n2,-d-,55/
And i set at!usbcomp=1,1,10D
I also installed ModemManager and setup the device whitelist in /lib/udev/rules.d/78-mm-whitelist-internal-modem.rules
as follows:
ACTION!="add|change|move", GOTO="mm_whitelist_internal_modem_end"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9071", ENV{ID_MM_DEVICE_PROCESS}="1"
LABEL="mm_whitelist_internal_modem_end"
However, ModemManager isn’t recognizing the modem firmware:
Feb 19 19:16:01 phone ModemManager[14170]: <warn> Couldn't get detailed info for PRI image with build ID '02.30.01.01_ATT': QMI protocol error (71): 'InvalidQmiCommand'
Feb 19 19:16:02 phone ModemManager[14170]: <warn> Couldn't get detailed info for PRI image with build ID '02.30.01.01_GENERIC': QMI protocol error (71): 'InvalidQmiCommand'
Feb 19 19:16:02 phone ModemManager[14170]: <warn> Couldn't get detailed info for PRI image with build ID '02.30.01.01_SPRINT': QMI protocol error (71): 'InvalidQmiCommand'
Feb 19 19:16:02 phone ModemManager[14170]: <warn> No valid firmware images listed. Assuming firmware unsupported.
Feb 19 19:16:02 phone ModemManager[14170]: <info> Modem: state changed (unknown -> disabled)
So I manually enabled the modem with mmcli -m 0 -e
Feb 19 19:16:04 phone ModemManager[14170]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: state changed (disabled -> enabling)
Feb 19 19:16:04 phone ModemManager[14170]: <warn> (ttyUSB2): port attributes not fully set
Feb 19 19:16:04 phone ModemManager[14170]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: 3GPP Registration state changed (unknown -> registering)
Feb 19 19:16:04 phone ModemManager[14170]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: 3GPP Registration state changed (registering -> home)
Feb 19 19:16:05 phone ModemManager[14170]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: state changed (enabling -> registered)
successfully enabled the modem
But ifconfig
is still not showing the interface, even after restarting NetworkManager.
How do I get the wwan interface to show in ifconfig?
