We are currently running the UMTS transmission path test as described in the “AirPrime MC7430 Product Technical Specification & Customer Design Guidelines” pdf.
We ran a similar test in the past for the MC7304 and MC7354 and using the AT!DAWSPARANGE=3 command we saw a change in the power.
On the MC7430, this command seems to have no effects…
Was there any changes in the MC74xx series that might have affected this?
We are following the steps as descried in the document.
The ultimate aim here is to change the RF power coming out of the module regardless of this command, are you able to do this? The MC73 and MC74 are completely different it might be that the PA does need to be set to high power.
I don’t have a spectrum analyser to hand to check it right now.
I have run the attached teraterm script against an MC7455 and it works with 3G as per the attached screen shot, the received power is reasonable given the number of connectors I had between the spectrum analyser and the MC74 itself. I am working on getting LTE working as it does not seem to be playing ball at the moment, will update you when I do get it working.
I have it on good authority that the below will work with LTE band 1.
AT!ENTERCND=“A710”
AT!DAFTMACT
290300 (290300 needed, otherwise send AT!RESET and try again the above commands)
AT!DASBAND=34 (LTE Band 1 selection)
0
AT!DALSTXBW=3 (10MHz bandwidth selection)
AT!DALSRXBW=3 (10MHz RX bandwidth selection)
AT!DASCHAN=18300 (Uplink 18300 channel selection, 1950MHz)
18176 (response is 18176, whatever the requested channel)
AT!DASTXON
AT!DALSWAVEFORM=1,50,10,0 (PUSCH signal (0=CW), 50 PUSCH resource blocks, 10 PUCCH resource blocks, start RB index 0)
AT!DALSPARANGE=0 (PA set to high power, 1 is for low power)
0
AT!DALSTXINDEX=90 (set the transmit power)
A +23dBm, 1950MHz, LTE modulated signal is generated
The signal power may be slightly different from +23dBm as the INDEX value is a raw uncalibrated command.
The 3G power level seems to be linked to the AGC value you set using the at!dawstxpwr command but I cannot test this at the moment but give it a go.
