Can you give me information about the EIRP Effective Isotropic Radiated Power? Unfortunately, I did not find anything in the technical specification.
Hi @mkirschner
EIRP is not dependent solely on module but also on Antenna gain and cable loss.
https://www.everythingrf.com/rf-calculators/eirp-effective-isotropic-radiated-power
You can refer to the above table from @jyijyi which is extracted from the MC7421 PTS. You can use the absolute maximum power including the tolerance and add your data related to antenna gain and cable loss to calculate your application EIRP.
Hope it helps.
Hi bbo,
thank you for fast answering and good help.
