2016-01-08 12:32:42,5, smsd: Moved file /var/spool/sms/outgoing/message to /var/spool/sms/checked
2016-01-08 12:32:43,6, GSM1: I have to send 1 short message for /var/spool/sms/checked/message
2016-01-08 12:32:43,6, GSM1: Sending SMS from to 33675152427
2016-01-08 12:32:43,6, GSM1: Checking if modem is ready
2016-01-08 12:32:44,7, GSM1: → AT
2016-01-08 12:32:44,7, GSM1: Command is sent, waiting for the answer
2016-01-08 12:32:44,7, GSM1: ← OK
2016-01-08 12:32:44,6, GSM1: Pre-initializing modem
2016-01-08 12:32:44,7, GSM1: → ATE0+CMEE=1;+CREG=2
2016-01-08 12:32:44,6, GSM1: Initializing modem
2016-01-08 12:32:45,7, GSM1: → AT^CURC=0
2016-01-08 12:32:45,7, GSM1: Command is sent, waiting for the answer
2016-01-08 12:32:45,7, GSM1: ← OK
2016-01-08 12:32:45,7, GSM1: → AT+CSQ
2016-01-08 12:32:45,7, GSM1: ← +CSQ: 7,99 OK
2016-01-08 12:32:45,6, GSM1: Signal Strength Indicator: (7,99) -99 dBm (Marginal), Bit Error Rate: not known or not detectable
2016-01-08 12:32:46,7, GSM1: → AT+CSQ
2016-01-08 12:32:46,7, GSM1: Command is sent, waiting for the answer
2016-01-08 12:32:46,7, GSM1: ← +CSQ: 7,99 OK
2016-01-08 12:32:46,6, GSM1: Signal Strength Indicator: (7,99) -99 dBm (Marginal), Bit Error Rate: not known or not detectable
2016-01-08 12:32:46,6, GSM1: Checking if Modem is registered to the network
2016-01-08 12:32:46,7, GSM1: → AT+CREG?
2016-01-08 12:32:46,7, GSM1: ← +CREG: 0,1,0708,318BD4 OK
2016-01-08 12:32:46,6, GSM1: Modem is registered to the network
2016-01-08 12:32:46,6, GSM1: Selecting PDU mode
2016-01-08 12:32:47,7, GSM1: → AT+CMGF=0
2016-01-08 12:32:47,7, GSM1: Command is sent, waiting for the answer
2016-01-08 12:32:47,7, GSM1: ← OK
2016-01-08 12:32:47,7, GSM1: → AT+CIMI
2016-01-08 12:32:48,7, GSM1: → AT+CGSN
2016-01-08 12:32:48,7, GSM1: Command is sent, waiting for the answer
2016-01-08 12:32:48,7, GSM1: ← OK
2016-01-08 12:32:48,5, GSM1: CGSN:
2016-01-08 12:32:48,5, GSM1: IMSI:
2016-01-08 12:32:48,7, GSM1: → AT+CMGS=25
2016-01-08 12:32:58,7, GSM1: put_command expected (>)|(ERROR), timeout occurred. 1.
2016-01-08 12:32:58,7, GSM1: ← OK
2016-01-08 12:32:59,7, GSM1: → 0011000B913376152524F70000FF0CF4F29C0E6A97E7F3F0B90C
2016-01-08 12:32:59,7, GSM1: Command is sent, waiting for the answer
2016-01-08 12:33:59,7, GSM1: put_command expected (OK)|(ERROR), timeout occurred. 2.
2016-01-08 12:33:59,7, GSM1: ←
2016-01-08 12:33:59,3, GSM1: The modem did not answer (expected OK).
