exars@exars-IStNX3-15HP038:~/workspace/legatoAF/legato-19.02.0$ make wp76xx
Building Legato for target ‘wp76xx’
Makefile:126: build/wp76xx/.config.mk: そのようなファイルやディレクトリはありません
modules/WiFi/moduleDefs:12: Legato WiFi version is undefined…
MAKE /home/exars/workspace/legatoAF/legato-19.02.0/bin/kconfig
make[1]: ディレクトリ ‘/home/exars/workspace/legatoAF/legato-19.02.0’ に入ります
COPY kconfig-frontends
RECONF kconfig-frontends
configure.ac:36: installing ‘scripts/.autostuff/scripts/compile’
configure.ac:23: installing ‘scripts/.autostuff/scripts/missing’
Makefile.am: installing ‘scripts/.autostuff/scripts/depcomp’
CONFIG kconfig-frontends
configure: error: can not find a lexer generator (such as lex or flex)
Makefile.hostTools:119: recipe for target ‘/home/exars/workspace/legatoAF/legato-19.02.0/build/tools/kconfig-frontends/config.status’ failed
make[1]: *** [/home/exars/workspace/legatoAF/legato-19.02.0/build/tools/kconfig-frontends/config.status] Error 1
make[1]: ディレクトリ ‘/home/exars/workspace/legatoAF/legato-19.02.0’ から出ます
Makefile:492: recipe for target ‘/home/exars/workspace/legatoAF/legato-19.02.0/bin/kconfig’ failed
make: *** [/home/exars/workspace/legatoAF/legato-19.02.0/bin/kconfig] Error 2
not sure if this helps:
no it still have same error
have you installed flex?
Are you using Ubuntu18 to build?
are you compiling in “leaf shell”?
still have a error but different one
(lsh:MANGOH-YELLOW-WP76XX) exars@exars-IStNX3-15HP038:~/workspace/legatoAF/legato-19.02.0$ make wp76xx
Building Legato for target 'wp76xx'
modules/WiFi/moduleDefs:12: Legato WiFi version is undefined...
make[1]: ディレクトリ '/home/exars/workspace/legatoAF/legato-19.02.0' に入ります
configure.ac:36: installing 'scripts/.autostuff/scripts/compile'
configure.ac:23: installing 'scripts/.autostuff/scripts/missing'
Makefile.am: installing 'scripts/.autostuff/scripts/depcomp'
configure: error: can not find a parser generator (such as yacc or bison)
Makefile.hostTools:119: recipe for target '/home/exars/workspace/legatoAF/legato-19.02.0/build/tools/kconfig-frontends/config.status' failed
make[1]: ディレクトリ '/home/exars/workspace/legatoAF/legato-19.02.0' から出ます
Makefile:492: recipe for target '/home/exars/workspace/legatoAF/legato-19.02.0/bin/kconfig' failed
does this help?
configure: error: can not find gperf
can you google the answer?
https://www.google.com/search?q=can+not+find+gperf&rlz=1C1CHBF_enHK817HK817&sourceid=chrome&ie=UTF-8
‘framework’ failed how to fixed?
MAKE kconfig-frontends
make[2]: ディレクトリ '/home/exars/workspace/legatoAF/legato-19.02.0/build/tools/kconfig-frontends' に入ります
GPERF libs/parser/hconf.c
LEX libs/parser/lconf.c
CC libs/lxdialog/libs_lxdialog_libkconfig_lxdialog_a-checklist.o
CC libs/lxdialog/libs_lxdialog_libkconfig_lxdialog_a-inputbox.o
CC libs/lxdialog/libs_lxdialog_libkconfig_lxdialog_a-menubox.o
CC libs/lxdialog/libs_lxdialog_libkconfig_lxdialog_a-textbox.o
CC libs/lxdialog/libs_lxdialog_libkconfig_lxdialog_a-util.o
CC libs/lxdialog/libs_lxdialog_libkconfig_lxdialog_a-yesno.o
AR libs/lxdialog/libkconfig-lxdialog.a
ar: `u' modifier ignored since `D' is the default (see `U')
YACC libs/parser/yconf.c
CC libs/parser/libs_parser_libkconfig_parser_la-yconf.lo
CCLD libs/parser/libkconfig-parser.la
CC frontends/conf/frontends_conf_kconfig_conf-conf.o
CCLD frontends/conf/kconfig-conf
CC frontends/mconf/frontends_mconf_kconfig_mconf-mconf.o
CCLD frontends/mconf/kconfig-mconf
CC frontends/nconf/frontends_nconf_kconfig_nconf-nconf.o
CC frontends/nconf/frontends_nconf_kconfig_nconf-nconf.gui.o
CCLD frontends/nconf/kconfig-nconf
CC utils/utils_kconfig_gettext-gettext.o
CCLD utils/kconfig-gettext
GEN frontends/kconfig
GEN utils/kconfig-tweak
make[2]: ディレクトリ '/home/exars/workspace/legatoAF/legato-19.02.0/build/tools/kconfig-frontends' から出ます
INSTALL kconfig-frontends
MAKE /home/exars/workspace/legatoAF/legato-19.02.0/bin/kconfig-set-value
GEN build/.KConfig/Documentation
GEN build/.KConfig/WiFi
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - TARGET_WP76XX
Setting val TARGET_WP76XX to 'y'
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - DEBUG
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - USE_CCACHE
Setting val USE_CCACHE to 'n'
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - CCACHE
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - TEST_COVERAGE
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - ENABLE_IMA
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - IMA_PRIVATE_KEY
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - IMA_PUBLIC_CERT
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - IMA_SMACK
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - ENABLE_SMACK
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - SMACK_ONLYCAP
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - SMACK_ATTR_NAME
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - SMACK_ATTR_VALUE
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - SDEF
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - SUPERV_NICE_LEVEL
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - SVCDIR_SERVER_SOCKET_NAME
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - SVCDIR_CLIENT_SOCKET_NAME
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - PYTHON
Setting val PYTHON to 'n'
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - PYTHON_EXECUTABLE
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - JAVA
Setting val JAVA to 'n'
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - JDK_INCLUDE_DIR
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - EJDK_DIR
KSET /home/exars/workspace/legatoAF/legato-19.02.0/.config.wp76xx - ENABLE_SECSTORE_ADMIN
GEN build/wp76xx/.config.mk
GEN version
GEN build/wp76xx/framework/include/le_config.h
MAKE tools
Using ninja installed at: /usr/bin/ninja
GEN /home/exars/workspace/legatoAF/legato-19.02.0/build/tools/build.ninja
Tools arch: x86_64
MAKE mkPatch
make[2]: ディレクトリ '/home/exars/workspace/legatoAF/legato-19.02.0/framework/tools/mkPatch' に入ります
CCLD /home/exars/workspace/legatoAF/legato-19.02.0/bin/mkPatch
make[2]: ディレクトリ '/home/exars/workspace/legatoAF/legato-19.02.0/framework/tools/mkPatch' から出ます
NINJA /home/exars/workspace/legatoAF/legato-19.02.0/build/tools/build.ninja
[63/63] Linking mk tools
GEN sources.md5
GEN package.properties
GEN build/wp76xx/config.sh
MAKE framework
GEN /home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/build.ninja
NINJA /home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/build.ninja
[53/53] Linking liblegato
CCLD /home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/bin/startSystem
MKEXE /home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/bin/supervisor
ninja: error: rebuilding '/home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/supervisor/build.ninja': '/home/exars/workspace/legatoAF/legato-19.02.0/build/tools/bin/mk', needed by '/home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/supervisor/build.ninja', missing and no known rule to make it
Makefile.framework:299: recipe for target '/home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/bin/supervisor' failed
make[1]: *** [/home/exars/workspace/legatoAF/legato-19.02.0/build/wp76xx/framework/bin/supervisor] Error 1
Makefile:599: recipe for target 'framework' failed
make: *** [framework] Error 2
have you done a “make clean” first before “make wp76xx”
yes. I already done it
no idea, i don’t see such problem…
log.txt (59.7 KB)
thanks you
already can use
