Loading a Root CA on HL7650
Hello ,
I am using HL7650 module.I am trying to write the key using AT+KCERTSTORE=0,1294,0
Unfortunately its throwing error 931.Would any one suggest me what is wrong in it.
Here us my root key.
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Hi @jagadeesh.kumar,
931- means “The length of a parameter is invalid”. Please check the length of the root key. I did a quick check on the key that you provided and it is more than 1294 bytes. Assuming the root key is provided correctly, the length appears to be 1488 bytes.
Please first confirm the file size is 1294? or 1590?
Make sure no CR/LF is added or changed during the transmition.
If you use the Teraterm tool, you can to send the cert with “File->sendFile->Binary”. “Binary” is mandotory.
Also, hardware flow control should be enabled in Tertaterm side.
Since the length is specified in +KCERTSTORE, then no need to send +++ to exit data mode of +KCERTSTORE.
Here’s my good result:
AT+KCERTSTORE=0,1590,0
CONNECT
//Send 1590 bytes of file.
AT+KCERTSTORE?
+KCERTSTORE:
root_cert,0,1590
aQNg95KnKGrrDUI=
local_cert,0,0
local_cert,1,0
local_cert,2,0
Thank you its a length issue.
