O/S: Raspberry Pi running Raspbian GNU/Linux 8 (jessie)
Kernel: Linux 4.9.24-v7+
Running dmesg shows
usb 1-1.4: config 1 has an invalid interface number: 8 but max is 4
usb 1-1.4: config 1 has an invalid interface number: 10 but max is 4
usb 1-1.4: config 1 has no interface number 1
usb 1-1.4: config 1 has no interface number 4
Interface driver qmi_wwan is properly registered. The wwan0 and wwan1 interfaces are properly created.
Ran qmi-network /dev/cdc-wdm0 start and network started successfully.
Ran dhclient wwan0 but cannot get the IP address.
I tried to change the data format qmicli -d /dev/cdc-wdm0 --wda-set-data-format=802-3, but the link layer protocol still remains raw-ip.
Am I missing something?
Are there any solutions to get the IP using the libqmi?
This is normal. It’s just Linux trying to be strict about USB interface numbering. Just a pointless warning which can be safely ignored.
dhclient does not support the qmi_wwan type of raw-ip interface. It can only work with ethernet (like) interfaces. You may have more success with e.g. udhcpc from BusyBox.
The MC/EM74xx has no 802-3 support, so changing the data format is not an option.
You can retrieve the IP config using QMI and congure the interface based on this instead of using DHCP. Try something like
