I’m trying to connect GPRS with TCP/IP trough a bearer, but I keep getting the following error if I build my code:
I can get my GPRS connection up till wip_netInit() but I can’t open the bearer, because my code won’t build.
I can’t find anything about the error on the forum or on the internet, is there anyone who knows how to solve this?
The error line numbers stay the same whatever I do with my code. A snippet of my code i placed bellow.
It seems to generate the error at the wip_bearerOpen() command.
I’m using the FXT009 with firmware R7.46.0.201108091301 and WIP Library 5.41.0.201102280815. Developer Studio 2.1.1 and [target]_ARM_ELF_GCC_Debug.
#include "adl_global.h"
#include "wip.h"
#define GPRS_APN ""
#define GPRS_USER ""
#define GPRS_PASSWORD ""
#define GPRS_PINCODE ""
void evh_bearer( wip_bearer_t b, s8 event, void *Context) {
TRACE((1, "evh_bearer()"));
switch( event)
case WIP_BEV_IP_CONNECTED:
TRACE((1, "GPRS bearer connected"));
adl_atSendResponse ( ADL_AT_UNS, "GPRS bearer opened\r\n");
break;
case WIP_BEV_IP_DISCONNECTED:
TRACE((1, "GPRS bearer disconnect"));
break;
default:
TRACE((1, "GPRS bearer event = %d", event));
break;
static void open_and_start_bearer( void) {
int r;
wip_bearer_t b;
r = wip_bearerOpen( &b, "GPRS", evh_bearer, NULL); //gives adl_gprsCmdAct error??
if(r != 0) TRACE((1, "wip_bearerOpen() : Fail"));
else{
r = wip_bearerSetOpts( b, WIP_BOPT_GPRS_APN, GPRS_APN,
WIP_BOPT_LOGIN, GPRS_USER,
WIP_BOPT_PASSWORD, GPRS_PASSWORD,
WIP_BOPT_END);
if(r != 0) {
TRACE((1, "wip_bearerSetOpts : Fail"));
wip_bearerClose(b);
else{
r = wip_bearerStart( b);
if(r != 0){
TRACE((1, "wip_bearerStart : Fail"));
TRACE((1, "ERROR CODE: %d",r));
Hope you guys can help
thanks in advance.
