Legato framework 14.07 Beta on github
Hi everyone.
We have pushed the 14.07 Beta version of the Legato framework onto github. The source is updated, but some features will not work until the next official firmware is available later this month. See the release notes for details.
In the meantime you can get the new source at github.com/repo
The new on-line documentation is at legato.io/docs
Upgrade instructions have been posted at legato.io/legato-docs/14_07/ … 14_07.html
Release notes are available at legato.io/legato-docs/14_07/ … 14_07.html
As usual, let us know of any issues and we’ll try and help you out.
The Legato Team.
LInk to Legato framework source on github: github.com/legatoproject/legato-af
Looks like a load of Linux magic spells & incantations to me (the linux noob)
:open_mouth:
Can we just download a new USB stick image with all the magic done & dusted :question:
See also: https://forum.sierrawireless.com/t/target-shows-only-ipv6-address/11951/6
The new firmware for Beta 14.07 with updated documentation is now available.
Specific firmware links:
upgrade info: legato.io/legato-docs/14_07/ … 14_07.html
downloads: developer.sierrawireless.com/Res … ution.aspx
The Legato Team
‘Upgrade WP Series Firmware’ references developer.sierrawireless.com/Res … ution.aspx - where the download links are:
WP7 series pre-built distribution: http://downloads.sierrawireless.com/legato/Legato-Dist-PreBuilt-mdm9x15-14.04.tar.bz2 Sources package: http://downloads.sierrawireless.com/legato/Legato-Dist-Source-mdm9x15-14.04.tar.bz2They look like the wrong versions - 14.04; should be 14.07 :question:
toolchain for Linux PC i686: http://downloads.sierrawireless.com/legato/Legato-Toolchain-mdm9x15-14.07-i686.tar.bz2 toolchain for Linux PC x86 64bits: http://downloads.sierrawireless.com/legato/Legato-Toolchain-mdm9x15-14.07-x86_64.tar.bz2They look OK
Windows drivers needed to upgrade WP7 Series firmware: http://downloads.sierrawireless.com/legato/Drivers_Package.zip WP7 firmware package: http://downloads.sierrawireless.com/legato/SWI9X15W_06.03.17.00-wp_yocto-cwe.exeAre they right :question: :question:
:confused:
Yes, my understanding is that the files are all correct. The Linux distribution files and Windows drivers did not require an update for 14.07, hence the two files with 14.04 in the name. The remaining files were updated for 14.07, along with the GitHub legato-af source.
