+KTCPSND response and delay
I was wondering what exactly the response OK means from the command +KTCPSND.
Is it that the data is transmitted (ie data is at the RF stage)?
I am seeing quite a big difference on the response time for OK between 1 byte and 3kbytes,
around 3 seconds.
thanks
Here is a document on how to capture wireshark log in HL78 module.
You can see when the OK is returned during the tcpdump log.
[HL7800] How to capture Wireshark trace.docx (224.6 KB)
So i have to match somehow the timings of the responses with the log?
yes, I think so, that will answer your question
An explanation in the datasheet would help. I’ve seen it in other modems.
thanks
I have made a test here:
AT+KCNXCFG=1,“GPRS”,“internet”
AT+KTCPCFG=1,0,“123.123.123.123”,5044
AT+ktcpcnx=1
AT+KTCPSND=1,5
12345
//here if I stop typing anything, the “12345” will still send to server and arrive server side.
//after that if I type “–EOF–Pattern–”, OK will be returned. So the OK is indicating you quit the data mode.
On your side, you can test the same and observe on server side:
after those 3 seconds delay and OK is received , are the data still transferring to server?
