HI
Im working with a Fastrack supreme 20 and Wipsoft 5.10.2020
Im creating a TCP client socket with the following line:
ClientSocket = wip_TCPClientCreateOpts(PEER_STRADDR, SERVER_PORT, evh,NULL,WIP_COPT_NODELAY,true, WIP_COPT_KEEPALIVE,true,WIP_COPT_END);
Ive read in the forum the WIP_COPT_KEEPALIVE is default off and fires every 2 hours.
I want to know if it is possible to increase the interval, if so, would I have to modify my socket creation command.
Thank You
davidc
October 8, 2009, 9:40am
2
Hiya,
Have a look at the wip_TCPClientCreateOpts() function.
Section 6.5.4.2 in the WIP Connectivity Guide describes the options available - one is WIP_COPT_KEEPALIVE - this may do what you want…
ciao, Dave
hi
Thanks for the reply.
Ive had a look at the Docs and im a little confused as how to create the channel with these options.
this is what I currently have,
According to the doc it should be: WIP_COPT_KEEPALIVE,1
Does the 1 represent true-false(0,1) or 1 x 10 millisecond , specifying the package send interval
thank you
davidc
October 8, 2009, 11:44am
4
Hiya,
According to my interpretation of the Docs I have here, it’s 1 x 10 millisecond.
Why do you think it means 'TRUE"?
ciao, Dave
hi
I found the following post indicating that the parameter is boolean
Re: default value of keepalive packets interval
Postby Ben FT » Tue Jun 09, 2009 11:54 am
I’ve been told that the docs are wrong on this. This is the info I had.
WIP_COPT_KEEPALIVE u32 value is valid for FTP channels only. The NOOP command will be sent every x tenth of the second; its off by default.
WIP_COPT_KEEPALIVE for TCP channels is only of boolean relevance; you can either set or reset; by default its off. The KEEPALIVE is sent every 2 hrs.
Hope that helps. It was good news for me.
davidc
October 8, 2009, 11:54am
6
Hiya,
Thanks for your link to the other post. Now I’m really confused.
I guess it’s time to go and hassle your Wavecom Distributor .
ciao, Dave
Hey
Your are right…!!! The WIP_COPT_KEEPALIVE parameter is actually a boolean and not an u32, that means one can only set the keep alive mechanism on or off, but not set its timer duration, which is set to 75 seconds( i am not sure where you read 2 hrs ) . Hence reading a value of 1 (TRUE) for WIP_COPT_KEEPALIVE means it is activated, while reading 0 (FALSE = default value) means it is deactivated…
Hope it helps you…
Can your app’ send dummy packets every 40 seconds?
