Issue getting new MC7430 Units online
Hello
I have used the MC7430 modules in the past and have recently received new orders. I am having an issue where i can not get the new modeling on the network. (Telstra in this case).
I have confirmed i am running the latest FW on the older and new modules, and am using the same system for testing. The older module will connect to the LTE network fine. Using the same sim with the new model they show as only have UMTS available, and when you try to connect to the network they say they are missing an API. However even after manually entering an APN i get the same issue.
Any help would be greatly appreciated. Thank you :slight_smile:
what is the response of the followings?
AT!ENTERCND=“A710”
ATi3
AT!Gstatus?
AT+cpin?
AT!UIMS?
AT!IMPREF?
at!selrat?
AT!band?
Hello, thanks for the reply. Please see responses before from both one of the modems I am having issues with and one of the older ones that are working.
Newer batch with isssue
at
At!ENTERCND=“A710”
ATi3
Model: MC7430
Revision: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30
MEID: 35907406150098
IMEI: 359074061500981
IMEI SV: 20
FSN: LU935385920110
+GCAP: +CGSM,+DS,+ES
AT!Gstatus?
!GSTATUS:
Current Time: 78 Temperature: 26
Reset Counter: 1 Mode: ONLINE
System mode: WCDMA PS state: Attached
WCDMA band: WCDMA 850
WCDMA channel: 4436
GMM (PS) state:REGISTERED NORMAL SERVICE
MM (CS) state: IDLE NORMAL SERVICE
WCDMA L1 state:L1M_PCH_SLEEP LAC: 2255 (8789)
RRC state: DISCONNECTED UTRAN Cell ID: 01401A37 (20978231)
RxM RSSI C0: -81 RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
AT+Cpin?
+CPIN: READY
AT!UIMS?
!UIMS: 0
At!IMPREF?
!IMPREF:
preferred fw version: 02.33.03.00
preferred carrier name: TELSTRA
preferred config name: TELSTRA_002.067_001
preferred subpri index: 000
current fw version: 02.33.03.00
current carrier name: TELSTRA
current config name: TELSTRA_002.067_001
current subpri index: 000
AT!selrat?
!SELRAT: 00, Automatic
AT!Band?
Index, Name, GW Band Mask L Band Mask TDS Band Mask
00, All bands, 100600000C400000 000001E0081600D5 0000000000000020
Older batch with no issues.
AT
AT!ENTERCND=“A710”
ATi3
Model: MC7430
MEID: 35907406071768
IMEI: 359074060717685
IMEI SV: 20
FSN: LU822375160310
+GCAP: +CGSM
AT!Gstatus?
!GSTATUS:
Current Time: 94 Temperature: 26
LTE band: B7 LTE bw: 20 MHz
LTE Rx chan: 3148 LTE Tx chan: 21148
LTE CA state: INACTIVE LTE Scell band:B7
LTE Scell bw:20 MHz LTE Scell chan:2950
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -87 RSRP (dBm): -115
PCC RxD RSSI: -94 RSRP (dBm): -140
SCC RxM RSSI: -100 RSRP (dBm): -120
SCC RxD RSSI: -104 RSRP (dBm): -135
Tx Power: – TAC: 3096 (12438)
RSRQ (dB): -11.7 Cell ID: 08199F1F (135896863)
SINR (dB): 6.0
AT+Cpin?
+CPIN: READY
AT!UIMS?
!UIMS: 0
AT!IMPREF?
!IMPREF:
at!selrat?
AT!Band?
How about you force it to use lte with at!selrat ?
Hello
I have attempted what you have suggested and ran the same command set below. After locking it to LTE only, it shows in the windows system as having no reception. This is using the same SIM and antenna as the working modem and so should have no issues getting reception.
What do you think I should try next?
Newer batch with isssue Locked to LTE
at
AT!entercnd=“A710”
Ati3
Model: MC7430
MEID: 35907406150001
IMEI: 359074061500015
IMEI SV: 20
FSN: LU935385030110
+GCAP: +CGSM
AT!Gstatus?
!GSTATUS:
Current Time: 3077 Temperature: 25
System mode: LTE PS state: Not attached
LTE CA state: NOT ASSIGNED
EMM state: Deregistered Attaching
RRC state: RRC Idle
PCC RxM RSSI: -81 RSRP (dBm): -112
PCC RxD RSSI: -94 RSRP (dBm): -139
RSRQ (dB): -11.4 Cell ID: 08199F1F (135896863)
SINR (dB): 9.8
At+cpin?
+CPIN: READY
At!Uims?
!UIMS: 0
AT!IMpref?
!IMPREF:
At!selrat?
!SELRAT: 06, LTE Only
At!band?
I saw someone saying to try AT!RMARESET
