I have read <AirPrime - Android RIL Integration Guide.pdf>,and I have some questions to ask.
I don’t know if this is enough for android framework to get location fix.
Is there any other GNSS framework and hal code to be modified?
I have also read <SierraWirelessLocationBasedServicesCDMAr2.pdf>,as it said,I have four options
to get location fix from Sierra Wireless module,Application programming interfaces,CnS commands,
AT commands,NMEA interface.So, which option does <AirPrime - Android RIL Integration Guide.pdf> use?
As you know,the call flow of Qcom is
startNavigating(GNSSLocationProvider.java) -> native_start() -> android_location_GnssLocationProvider_start(Native)
-> HIDL -> gps.default.so.
So,when we use Sierra WP7603,not qcom modem, if the call flow is the same? Do we just need to replace gps.default.so with yours?
