Hi~
I am trying to use the IRQ and ExtInt services on a Q2686 to monitor when an interrupt occurs on INT1 . When PC sent a one byte data to 2686 , the Interrupt will occurs .
If i dont do adl_busRead in irq_DataHandler , the interrupt pulse is ok.
If i do adl_busRead in irq_DataHandler , the interrupt pulse is not ok.
The pulse like reset .
Any idea ?
Hi xander1979520;
I’m using SCTU and IRQ service, too.
I think it will be better if you up load your code.
It’s easier to solve your problem if we can see your code.
I have the same problem, I am trying to read a value from chip that is connected to wavecom with SPI and if I call adl_busRead function while in Interrupt routine Wavecom Supreme resets.
