IPC: Passing "big" buffer to server
My app has to send some data to the network. These data are collected from a component (A) and send to another (B) in order to be sent to the network.
The component in charge of the sending to the remote server provides following API:
FUNCTION int connect
	string url[32] IN,
	int port IN,
	string deviceId[32] IN,
	string username[32] IN,
	string password[32] IN
FUNCTION int publish
	string payload[MAX_BUFFER_SIZE] IN,
	int payloadlength IN
I noticed that when the MAX_BUFFER_SIZE is set to a value > 1000 the value of payloadlength is not correct in my server.
For exemple if A called the publish service with a buffer size equals to 4900 bytes and as a consequence the payloadlength equals 4900 the payloadlength received into my component B is not equal to 4900 (As an example I just had 1853212).
[]Is this a legato limitation ?[/]
[]What can you advise me to send big buffer through an IPC ? should I use file to log my data and read them from the service function[/]
Note: I have to acquired about 500 bytes of data per seconds.
Thanks for your help !
David
Hello David,
The current maximum message payload is in fact 1000 bytes as you have seen. Now that ifgen supports type definitions, this limitation should be addressed in a future release.
In the mean time, one option for handling this is to create a pipe and pass your data through it.
   string url[32] IN,
   int port IN,
   string password[32] IN,
   file publishData IN
Then you can monitor that file descriptor using the event API.
http://www.legato.io/legato-docs/15_01/c_event_loop.html#c_event_files
-Kelly
