I want to send simple string using FTP
Hello
I have a simple application which I want to send only those fixed lines in [color=red]RED below by FTP (as I wrote into address toolbar at IE web page and click )
[color=red]http://www.roro.co.il/test/g24_cc/report.php?IMEI=004400009817014&MSISDN=0546306299&CurrentRead=200
(its not link - thats I want to send the website and data)
I am using Q2406B Open AT V2.10
Haim Rodrik
Any particular reason why you want to use FTP to do that?
Hi
First, establish GPRS/EDGE session with access to the Internet. Then, connect to Your server via tcp_client. And finally, exchange data using well defined http protocol.
Here is small (but very good) tutorial: jmarshall.com/easy/http/
But, surely, if you connect to an FTP server, you must use FTP protocol?! :open_mouth:
Yes, it looks pretty useful at a first glance! :smiley:
It starts with a reference to a BSD Sockets tutorial:
frostbytes.com/~jimf/papers/ … ckets.html
Windows users might like to know that there is also a Windows version at:
frostbytes.com/~jimf/papers/ … nsock.html
Thanks to friends
In this particular application I have GPRS sesion wich the module sends strings to the server by TCP/IP prptocol. In this case I set the module with IP number an PORT number. Its works 100%
I need to do the same action to send same string which in some VARIABLE to send by FTP instead TCP/IP
I see in the forum a sample code for that But I don’t know where exactly I need to insert writgh codes to cause the module will works in FTP mode
Thanks again
Hello again
This codes I finded in this forum.
The server side its works 100% also. When I put the string
on address text box of the IE and pressing its works
PI Componentes - Gustavo M. Nunes
Objetivo:  Enviar um arquivo texto para um servidor FTP
Descricao:
         1) Criar um comando "at+ftp" que inicia a trasnferencia FTP
Upgrades:  --//--
Data Criacao:      22-Fev-2006
Ultima Atualizacao: 22-Fev-2006
#include "adl_global.h"
#include "ed_gprs.h"
#include "ed_dialup.h"
#include "ed_ftp.h"
#include "ed_msgcodes.h"
   Mandatory variables
   wm_apmCustomStack
   wm_apmCustomStackSize
u32 wm_apmCustomStack [ 256 ];
const u16 wm_apmCustomStackSize = sizeof ( wm_apmCustomStack );
ed_gprsSetupParams_t   ParamsGPRS;
ed_FTPSetupParams_t      ParamsFTP;
ed_FTPPutFileParams_t   ParamsFile;
   Function   : Config
   Description: Setup every information for parameters
   Variable Name     |IN |OUT|GLB|  Utilisation
void Config ()
   //Configuracao da conexao GPRS com o operadora
   ParamsGPRS.Cid = 1; //Configura canal 1 de conexao (4 canais estao disponiveis)
   ParamsGPRS.Mode = 1; //Configura o modem para conexao GPRS
   wm_strcpy(ParamsGPRS.ApnServ,"tim.br");  //APN da servidora TIM
   wm_strcpy(ParamsGPRS.ApnUn,"tim");
   wm_strcpy(ParamsGPRS.ApnPw,"tim");
   //FTP configuration
   ParamsFTP.FtpPort = 21;
   ParamsFTP.FtpType = 'A';
   wm_strcpy(ParamsFTP.FtpServ,"200.162.41.205");
   wm_strcpy(ParamsFTP.FtpUn,"xx");
   wm_strcpy(ParamsFTP.FtpPw,"xx");
   wm_strcpy(ParamsFile.FtpPutFilename,"testeftp01.txt");
   wm_strcpy(ParamsFile.FtpPutPath,".");
   Function   : FtpPutHandler
   Description: Callback dos eventos da conexao FTP
   ResponseCode      |   |   |   |  Report FTP status
   id                |   |   |   |  Sempre retorna ED_ID_FTP_PUT
void FtpPutHandler(s32 ResponseCode,TeDHandle id){
   char msg[20];
   sprintf(msg,"Put Handler: %d\n\r",ResponseCode);
   adl_atSendResponse ( ADL_AT_UNS, msg);
   Function   : FtpPutData
   Description: Essa funcao ? chamada quando o servidor FTP esta apto a
             receber arquivos
   MaxLen            |   |   |   |  Numero maximo de bytes que podem ser
                 |   |   |   |  enviados no momento
void FtpPutData(u16 MaxLen,TeDHandle id){
   ascii teste[100]="Exemplo FTP - PI Componentes";
   u8   * ptr = NULL;
   ptr = teste;
   adl_atSendResponse ( ADL_AT_UNS, "FTP Put Data Event\n\r");
   ed_SendData(ptr,strlen(teste),TRUE);
   Function   : ConexaoFTP
   Description: Inicia conexao com o FTP e trasmissao do arquivo
void ConexaoFTP ()
   //Variaveis
   char msg[20];
   s8 sreturnCode;
   sreturnCode = ed_FTPSetConfig(&ParamsFTP);
   if(sreturnCode==0)
      //FTP configuration ok
      adl_atSendResponse ( ADL_AT_UNS, "FTP configurado com sucesso\n\r");
      sreturnCode = ed_FTPPutFileSetConfig(&ParamsFile);
      if(sreturnCode==0){
         //Paramentros do arquivo configurado com sucesso
         adl_atSendResponse ( ADL_AT_UNS, "Arquivo FTP configurado com sucesso\n\r");
         //Iniciar transferencia FTP
         ed_FTPPut(FtpPutHandler,FtpPutData);
      }else{
         //Falha na configuracao do arquivo
         adl_atSendResponse ( ADL_AT_UNS, "Erro na configuracao do arquivo FTP\n\r");
   }else{
      //FTP configuration failed
      adl_atSendResponse ( ADL_AT_UNS, "Erro nos parametros FTP\n\r");
      sprintf(msg,"+Erro: %d\n\r",sreturnCode);
   Function   : DialupHandler
   Description: ed_DialupConnectionStart Handler
   ResponseCode      |   |   |   |  Report Dialup status
void DialupHandler(s32 ResponseCode){
   char msg[20];
   s8 sreturnCode;
   switch (ResponseCode){
   case ED_OK_GPRS_SESSION_SET:  // GPRS online
      adl_atSendResponse ( ADL_AT_UNS, "GPRS conectado\n\r");
      //Inicia conexao FTP
      ConexaoFTP();
      break;
   default:
      //Erro na conexao GPRS
      adl_atSendResponse ( ADL_AT_UNS, "Erro na conexao GPRS\n\r");
      break;
   Function   : TimerHandler
   Description: adl_tmrSubscribe Handler
   tmerId            |   |   |   |  Say which time Id is running at the
                 |   |   |   |    moment
void TimerHandler(u8 timerId){
   char msg[20];
   s8   sreturnCode;
   sreturnCode = ed_DialupConnectionStart(DialupHandler);
   if(sreturnCode == 0){
      //GPRS Conectado
      adl_atSendResponse ( ADL_AT_UNS, "Diaul up Ok\n\r");
   }else{
      //Verifica se GPRS ja nao esta conectado
      if(sreturnCode == ED_ERR_MODEM_RUNNING)
         adl_atSendResponse ( ADL_AT_UNS, "GPRS ja conectado\n\r");
         ConexaoFTP ();
      }else{
         //Falha na conexao GPRS
         adl_atSendResponse ( ADL_AT_UNS, "Falha no Dial Up\n\r");
   Function   : GPRSHandler
   Description: Callback do comando "at+cgatt=1" que ? enviado pela funcao
             GPRSConnection
   paras             |   |   |   |  CmdCreate answer
bool GPRSHandler(adl_atResponse_t *paras){
   s8      sreturnCode = ERROR;
   char   msg[20];
   if( !wm_strncmp(paras->StrData,"\r\nOK",4)){
      //Comando AT+CGATT executado com sucesso
      sreturnCode = ed_GprsSetConfig(&ParamsGPRS);
      if (sreturnCode == 0){
         //Parametros OK
         adl_atSendResponse ( ADL_AT_UNS, "Parametros Ok\n\r");
         adl_tmrSubscribe(FALSE,10,ADL_TMR_TYPE_100MS,TimerHandler);
      }else{
         //Parametros com erro
         adl_atSendResponse ( ADL_AT_UNS, "Erro nos parametros GPRS\n\r");
   }else{
      //Erro ao tentar usar o comando AT+CGATT
      adl_atSendResponse ( ADL_AT_UNS, "Falha na conexao GPRS\n\r");
   return TRUE;
   Function   : GPRSConnection
   Description: Inicia conexao GPRS
void GPRSConnection (){
   adl_atSendResponse ( ADL_AT_UNS, "Abrindo conexao GPRS...\n\r");
   adl_atCmdCreate("AT+CGATT=1",TRUE,GPRSHandler,"*",NULL);
   Function   : AtFTP
   Description: Callback do comando "at+ftp"
   paras             |   |   |   | Parametros do comando
void AtFTP(adl_atCmdPreParser_t * paras)
   //Inicia conexao GPRS
   GPRSConnection();
   //Mensagem de retorno do comando AT
   adl_atSendResponse ( ADL_AT_RSP, "OK\n\r");
   Function   : SimCard
   Description: Display the SimCard Events
   Event             |   |   |   | Sim Card Events
void SimCard (u8 Event){
   switch(Event){
   //Normal Events
   case ADL_SIM_EVENT_PIN_OK:
         adl_atSendResponse ( ADL_AT_UNS, "PIN Code Ok\n\rConectando...\n\r");
   break;
   case ADL_SIM_EVENT_REMOVED:
         adl_atSendResponse ( ADL_AT_UNS, "SimCard Removido\n\r");
   break;
   case ADL_SIM_EVENT_INSERTED:
         adl_atSendResponse ( ADL_AT_UNS, "SimCard Inserido\n\r");
   break;
   case ADL_SIM_EVENT_FULL_INIT:
         adl_atSendResponse ( ADL_AT_UNS, "Conectado !\n\r");
         //Cria comando para conectar no servidor FTP
         adl_atCmdSubscribe("at+ftp",AtFTP,ADL_CMD_TYPE_ACT);
   break;
   //Error Events
   case ADL_SIM_EVENT_PIN_ERROR:
         adl_atSendResponse ( ADL_AT_UNS, "PIN Code Incorreto\n\r");
   break;
   /*Erro quando se e necessario inserir o PIN Code.
     Por comandos AT, insera o PIN Code usando
     AT+CPIN="xxxx", onde xxxx e o codigo de 4 digitos*/
   case ADL_SIM_EVENT_PIN_WAIT:
         adl_atSendResponse ( ADL_AT_UNS, "Entre com o PIN Code\n\r");
   break;
   Function   : adl_main
   Description: Main function
   InitType          |   |   |   | Application start mode reason
   //Inicio da aplicacao
   adl_atSendResponse(ADL_AT_UNS, "\n\rInicio da aplicacao\n\r");
   //Executa a funcao SimCard a cada evento que ocorrer
   adl_simSubscribe(SimCard,NULL);
   //Inicializa?ao das bibliotecas IP
   ed_Init();
   //Configura parametros diversos
   Config();
I tried to copy and pasted but its missing some links Its not works
Thanks again
[/code]
What do you mean, “its works” :?:
What exactly does it do?
Note that, when you type that line in IE, it will be using HTTP - it will not be using FTP!
Both the link in the HTTP tutorial, and the one given above now seem to be dead.
The document is currently available here: cis.temple.edu/~ingargio/old … ckets.html
That link is also broken; try: burks.bton.ac.uk/burks/pcinfo/pr … insock.htm
