When I downloaded the first time the ping gprs sample into the Q2687 modem (Dev. Kit) using at+wdwl (after that I reset it using at+cfun=1) then
I run the sample with at+wopen=1
Then
I Execute:
at+gset=1,“empresarial.itelcel.com”,“webgprs”,“webgprs”,“0xx.xxx.00x.171”,0,0 to put the PDP Context (This is a fixed IP assigned by the network operator)
A standard part of all software development is debugging - and now it is time for you to start debugging!
A standard process would be to look at the source code to see where that message could be generated, and what could cause it to be generated ;
if that doesn’t show the answer, think about what additional diagnostic output (eg Trace) you could add to give you more information to go on…
