The WP modules come in 2 hardware variants depending on the used memory chips. Is there a way to tell which variant is a certain module by reading something on it?
We can program them with an image from before the new variant, e.g R12 and see if it fails, but I’m wondering if there’s an easier way.
the new memory could appear in any new WP module
Since you have one module with old memory and one module with new memory, you can compare the return in that command
That was the original plan but I’ve seen different part numbers in Variant 2 modules. I’d feel more comfortable if we had a definitive list of part numbers to eliminate doubt.
Some regions require a custom firmware and we’ve had trouble with the variants in the past. Also from a traceability point of view, it’s beneficial for us to know what variant is each module, to help us troubleshoot when things go wrong.
Probing the memory part is a nice way of doing it so just need to know for certain which parts belong to which variant.
I see different part numbers but I’d prefer a source of truth type of reference. I assume there might be subtle changes in the part numbers for a given variant too and I would think the IDs are tracked somewhere in the codebase.
Yes and I can read the flash part number this way but the missing information is which part numbers belong to which variant. Checking a handful of known modules may give me some information and I’m looking for some sort of acknowledgment that the same part numbers apply to our existing fleet and new units.
