How to stop WIND & CREG indications on Terminal Emulator?
#1
Hi All,
 I am connected Fastrack Supreme to AMR (Power Meter). when Fastrack Supreme is booting, some wind and creg indications are comming on Terminal Emulator. I tried with AT+WIND=0 and AT+CREG=0, but still i am getting the command like +CGREG: 0
 How to stop these indications? I have to send some AMR own cammonds from Fastrack Supreme to AMR. Due to this wind and creg indications i am not able to get the exact data from AMR. Please tell me how to stop this.
Thanks & Regards
ARISE
#2
Hi ariseramesh8,
When you config AT+WIND=0 => no +WIND response will send out.
When you config AT+CREG=0, you must to save this config to EPROM by AT&W.
ttt
#3
HI
I am also using the wavecom modem for AMR with GPRS. Following is the architecture that we are having
Meter----------->Wavecom Modem---------------->GPRS.
In the above scenario we need altleast 2 COM ports one for connecting to the Meter and another for Debugging/downloading. How to manage both using the single COM Port.
Pls help us in resolving the same.
Thanks a lot in advance.
KR
#4
For Debugging/downloading, why not just use the IESM with the 2nd COM port?
Alternatively, Look in the Tools Manual in the section titled Development Toolkit- it shows you how to connect your application to the target through the PC:
[attachment=0]Wavecom_TE_External_Com.gif[/attachment]
#5
The forum seems to have lost the attachment.
It should have looked something like this:
