How to read charging status of Fastrack Supreme battery
Hello
I am powering the FAstrack Supreme 20 with a solar panel circuit. It supplies 12Volts. I will like to know if there is a function in the ADL interface that gives the charging level of the Fastrack Supreme Battery. I have checked the ADL Development user guide but i did not find any.
The Fastrack has a switch-mode power supply - that’s how it can work with any supply from 6V - 32V!
Therefore, it is not aware internally of what the external supply voltage is.
If you use an IESM card, you could use one of the Analogue-to-Digital channels to monitor your battery voltage…
Thanks for your reply. I will like to know if there is an ADL function which can be used to shut down the Fastrack Supreme from the OpenAT application.
