Dear support:
I used the MC7304 , and loaded the driver , now I can see the ttyUSB and qcqmi ports ,also there are two wwan ports,wwan0 and wwan1
but when I run qmi call on the system, I failed.
I RUN the commad <adb logcat –b radio> , I Got the below log :
09-12 14:24:37.230 I/use-Rlog/RLOG-RIL( 2360): Entering RIL_Init…
09-12 14:24:37.230 I/use-Rlog/RLOG-RIL( 2360): Network interface was not supplied, falling back on usb0!
09-12 14:24:37.240 I/use-Rlog/RLOG-RIL( 3236): Runtime 3G port found matched device with Name:SIERRA-MC7304 idVendor:1199 idProduct:68c0
09-12 14:24:37.240 I/use-Rlog/RLOG-RIL( 3236): Current modem type = 5
09-12 14:24:37.240 D/use-Rlog/RLOG-RILD( 3236): Couldn’t find proper modem, retrying…
09-12 14:24:41.110 I/RILJ ( 2957): Couldn’t find ‘rild’ socket; retrying after timeout
09-12 14:24:42.250 I/use-Rlog/RLOG-RIL( 3236): 3G modem monitor thread is start
09-12 14:24:42.660 I/use-Rlog/RLOG-RIL( 3236): Entering RIL_Init…
09-12 14:24:42.660 I/use-Rlog/RLOG-RIL( 3236): Network interface was not supplied, falling back on usb0!
09-12 14:24:42.690 I/use-Rlog/RLOG-RIL( 3259): Runtime 3G port found matched device with Name:SIERRA-MC7304 idVendor:1199 idProduct:68c0
09-12 14:24:42.700 I/use-Rlog/RLOG-RIL( 3259): Current modem type = 5
09-12 14:24:42.700 D/use-Rlog/RLOG-RILD( 3259): Couldn’t find proper modem, retrying…
09-12 14:24:45.110 I/RILJ ( 2957): Couldn’t find ‘rild’ socket; retrying after timeout
09-12 14:24:47.700 I/use-Rlog/RLOG-RIL( 3259): 3G modem monitor thread is start
09-12 14:24:48.110 I/use-Rlog/RLOG-RIL( 3259): Entering RIL_Init…
09-12 14:24:48.110 I/use-Rlog/RLOG-RIL( 3259): Network interface was not supplied, falling back on usb0!
09-12 14:24:48.140 I/use-Rlog/RLOG-RIL( 3293): Runtime 3G port found matched device with Name:SIERRA-MC7304 idVendor:1199 idProduct:68c0
09-12 14:24:48.140 I/use-Rlog/RLOG-RIL( 3293): Current modem type = 5
[b]we can see that the mc7304 has been detected , and the android system is also looking for usb0. BUT there are only WWANX ports on the system, I don't know how to do next ,can you give me some advice ? thanks.
[/b]
