I have a fastrack supreme 10 modem, using adl is it possible to instruct the GPIO to hold a ‘high’ state(high bit) for a amount of time(eg. 5mins)
Shafeer
Shafeer
Hiya,
Are you writing your own application, or relying on the internal AT commands?
If you are writing your own application, you can use a timer or calendar alarm event to generate pretty much any time you want. If you’re relying on the internal AT commands, I don’t think that there’s anything there…so you might (probably) have to write a simple application to do this.
Have a look at : adl_tmrXXXX() functions, adl_rtcXXXX() functions, adl_gpioXXXX() fucntions and the AT+CALA command. This should give you a good starting point…
ciao, Dave
Thanks for your reply
I will be using adl_tmrsubscribe, but i want to know if adl_tmrsubscribe has maximum time?
in other words,using this hello world code as a reference
TRACE (( 1, "Embedded : Appli Init" ));
/* Set 1s cyclic timer */
adl_tmrSubscribe ( TRUE, 10, ADL_TMR_TYPE_100MS, HelloWorld_TimerHandler );
can i modify it to wait for around 20 mins?
In this way…
/* Set 20mins(1200s) cyclic timer */
adl_tmrSubscribe ( TRUE, 12000, ADL_TMR_TYPE_100MS, HelloWorld_TimerHandler );
Hiya,
Sure does. Look in the ADL guide for the value of ADL_TMR_100MS_MAX_VALUE (Section 3.4.3.1 in the ADL R7.4 version). According to the guide, the max period for the timer is around 7 days.
For long duration events, you might be better to read the real-time clock (using adl_rtcXXX()), and subscribe to the +CALA unsolicited event, and then set an alarm sometime in the future using a call to AT+CALA. It’s a bit messy (some ADL calls, some AT commands) though.
ciao, Dave
if you would look at the documentation you will find that:
great thanks for prompt replies
i wont be needing 7 days long timer…max a few hours only
just another thing, my (one-shot timer)timer is gonna activate everytime a sms is recieved
According to the user guide:
adl_tmr_t *tt
void Timer_Handler(u8 Id, void * Context)
adl_atsendResponse...
//Timer is not unsubscribed since it expires "naturally"
bool SMS_AUTO_Handler(ascii *SmsTel, ascii *SmsTimeOrLength, ascii *SmsText)
tt = adl_tmrSubscribe ( FALSE, 12000, ADL_TMR_TYPE_100MS, Timer_Handler);
Since the one shot timer is not unsubscribed, whenever a new message is recieved, will it overwrite the old subscription?
