I am trying to figure out if i have the HL8518 with me and if i want to interface it with some MicroProcessor which would be running Linux OS. What would be the Linux driver i would use ? I see USB drivers, but i could not find UART drivers which would drive HL8518 from Linux OS.
Please let me know if we have in house driver or if i can use any generic driver for HL8518.
I have a custom target and not a dev a kit. Today we are using AT commands for all the communications with the modem. We want to remove that and understand if a driver can create a network interface for applications in the user space to use.
So what i understand is that we can use a driver (which driver?) in the kernel space which will create a network interface for applications to use on the user space and we need a USB line also to execute some AT commands which is not handled by the driver. Is my understanding correct ?
If so, do you know what are those special AT commands which the driver cannot handle over UART ? Also which driver are you suggesting we should use to get the network interface ?
Thanks @jyijyi . So i guess we will get a ppp0 network interface on the Linux environment. I was hoping the same driver would allow me to send the AT command through IOCTL from the user application.
