HL7812 static DNS
I want to use static DNS with the HL7812 modem with the latest firmware.
However, this command errors out:
AT+KCNXCFG=1,“GPRS”,“iot.1nce.net”,“”,“”,“IPV4”,“0.0.0.0”,“168.63.129.16”,“8.8.8.8”
+CME ERROR: 932
which indicates that there is some invalid parameter but I can’t find where the issue is.
Can the DNS not be statically configured?
thanks
Same problem in rc76:
Btw, will you consider to use udp connection to your cns server for querying the ip address?
I am able to connect to the server using the DNS name but not with the IP.
Does this make sense? What could I possibly do to fix this?
I won’t be using UDP for now.
thanks
what did you see if you use real ip?
I get ktcp notif: 1,13
13 — SSL connection error
Have you tried not using SSL?
I haven’t as I don’t have control over that server, but successful connection via SSL and the DNS name is possible… So just by changing from the IP to the DNS, it works.
I guess probably you have input the wrong IP address
you might need to set up another server to test
