I just wanted to share logs for both cases (failure and success) again:
Succesfull connection on another board:
[00:01:59.614,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KCNXCFG=1,"GPRS","",,,"IPV4V6"]
[00:01:59.617,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
[00:01:59.634,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:01:59.634,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:01:59.634,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KTCPCFG?]
[00:01:59.635,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
[00:01:59.640,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:01:59.640,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:01:59.640,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KUDPCFG?]
[00:01:59.641,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
[00:01:59.646,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:01:59.646,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:01:59.646,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+CGCONTRDP=1]
[00:01:59.647,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
+CGCONTRDP: 1,5,"net",10.149.39.65.255.255.255.252,10.149.39.66,10.105.16.254,10.105.144.254,,,,,,
[00:01:59.660,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +CGCONTRDP: (len:119)
[00:01:59.660,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IP info: 119 1,5,"net",10.149.39.65.255.255.255.252,10.149.39.66,10.105.16.254,10.105.144.254,,,,,,,,,
[00:01:59.660,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IP string len: 29
[00:01:59.660,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IP addr: 10.149.39.65
[00:01:59.660,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IPv4 DNS addr: 10.105.16.254
[00:01:59.661,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:02:01.661,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KUDPCFG=1,0,,,,,0,0]
[00:02:01.663,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET11: 0
+KUDPCFG: 1
[00:02:01.698,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KUDPCFG: (len:1)
[00:02:01.698,000] <dbg> modem_hl7812: on_cmd_sockcreate: +KUDPCFG: 1
[00:02:01.698,000] <dbg> modem_hl7812: on_cmd_sockcreate: look up new socket by creation id
[00:02:01.699,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
+KCNX_IND: 1,1,0
[00:02:01.717,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KCNX_IND: (len:5)
[00:02:01.717,000] <dbg> modem_hl7812: on_cmd_kcnx_ind: CNX_CNF: 1, STATUS: 1
[00:02:01.717,000] <inf> modem_hl7812: Connected with AF: 0
+KUDP_IND: 1,1
[00:02:02.733,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KUDP_IND: (len:3)
[00:02:02.733,000] <dbg> modem_hl7812: on_cmd_sock_ind: +KUDP_IND ID: 1
[00:02:02.733,000] <dbg> modem_hl7812: allow_sleep: Keep sleep
[00:02:02.733,000] <dbg> modem_hl7812: offload_bind: offload_bind
[00:02:02.733,000] <dbg> modem_hl7812: dns_work_cb: DNS ready
[00:02:02.733,000] <dbg> modem_module: pdn_event_handler: PDN_EVENT_ACTIVATED
[00:02:02.733,000] <dbg> LTE_HL7812: iface_ready_evt_handler: LTE is ready!
[00:02:02.734,000] <dbg> LTE_HL7812: iface_ready_evt_handler: LTE is ready!
[00:02:02.734,000] <dbg> modem_module: state_set: State transition STATE_DISCONNECTED --> STATE_CONNECTED
[00:02:02.734,000] <dbg> cloud_module: state_set: State transition STATE_LTE_DISCONNECTED --> STATE_LTE_CONNECTED
[00:02:02.734,000] <dbg> cloud_module: connect_cloud: Connecting to cloud
[00:02:02.734,000] <wrn> cloud_module: CLOUD CONNECT RETRIES: 0
[00:02:02.734,000] <dbg> cloud_module: connect_cloud: Cloud connection establishment in progress
[00:02:02.734,000] <dbg> cloud_module: connect_cloud: New connection attempt in 32 seconds if not successful
[00:02:02.853,000] <dbg> aws_iot_integration: aws_iot_event_handler: AWS_IOT_EVT_CONNECTING
[00:02:02.853,000] <dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTING
[00:02:02.854,000] <dbg> modem_hl7812: offload_recv: offload_recv
[00:02:02.854,000] <dbg> modem_hl7812: offload_sendto: offload_sendto
[00:02:02.854,000] <dbg> modem_hl7812: allow_sleep: Keep awake
[00:02:02.854,000] <dbg> modem_hl7812: allow_sleep_with_timeout: Keep awake
[00:02:02.854,000] <dbg> modem_hl7812: is_cmd_ready: 265 LOWPOWER VGPIO:1 GPIO6:1 UART_CTS:0
[00:02:02.854,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KUDPSND=1,"10.105.16.254",53,64]
CONNECT
[00:02:02.869,000] <dbg> modem_hl7812: hl7812_rx: HANDLE CONNECT (len:0)
[00:02:02.945,000] <dbg> modem_hl7812: send_data: Sent 64 bytes
[00:02:02.952,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:02:02.952,000] <dbg> modem_hl7812: allow_sleep: Keep sleep
+KUDP_DATA: 1,192
[00:02:03.772,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KUDP_DATA: (len:5)
[00:02:03.772,000] <dbg> modem_hl7812: allow_sleep: Keep awake
[00:02:03.772,000] <dbg> modem_hl7812: allow_sleep_with_timeout: Keep awake
[00:02:03.772,000] <dbg> modem_hl7812: is_cmd_ready: 265 LOWPOWER VGPIO:1 GPIO6:1 UART_CTS:0
[00:02:03.772,000] <dbg> modem_hl7812: start_socket_rx: Start socket RX ID:1 size:192
[00:02:03.772,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KUDPRCV=1,192]
CONNECT
[00:02:03.783,000] <dbg> modem_hl7812: hl7812_rx: HANDLE CONNECT (len:0)
[00:02:03.783,000] <dbg> modem_hl7812: sock_read: Socket 1 RX 192 bytes
[00:02:03.783,000] <dbg> modem_hl7812: wait_for_modem_data: cur:0, exp:1
[00:02:03.833,000] <dbg> modem_hl7812: sock_read: Processing RX, buf len: 234
[00:02:03.834,000] <dbg> modem_hl7812: sock_read: Got all data, get EOF and OK (buf len:42)
[00:02:03.834,000] <dbg> modem_hl7812: sock_read: Sock 1 RX done
[00:02:03.834,000] <dbg> modem_hl7812: allow_sleep: Keep sleep
+KUDP_RCV: "10.105.16.254",53
[00:02:03.834,000] <dbg> modem_hl7812: hl7812_rx: UNHANDLED RX IN2
2b 4b 55 44 50 5f 52 43 56 3a 20 22 31 30 2e 31 |+KUDP_RC V: "10.1
30 35 2e 31 36 2e 32 35 34 22 2c 35 33 |05.16.25 4",53
[00:02:03.834,000] <dbg> modem_hl7812: sockreadrecv_cb_work: Sock 1 RX CB (size: 220)
[00:02:03.931,000] <dbg> aws_iot_netfeasa: broker_init: IPv4 Address found 52.213.132.116
[00:02:03.938,000] <dbg> modem_hl7812: offload_get: offload_get
[00:02:03.938,000] <dbg> modem_hl7812: allow_sleep: Keep sleep
[00:02:03.938,000] <dbg> modem_hl7812: offload_recv: offload_recv
[00:02:03.938,000] <dbg> modem_hl7812: offload_bind: offload_bind
[00:02:03.938,000] <dbg> modem_hl7812: offload_connect: offload_connect
[00:02:03.938,000] <dbg> modem_hl7812: allow_sleep: Keep awake
[00:02:03.938,000] <dbg> modem_hl7812: allow_sleep_with_timeout: Keep awake
[00:02:03.938,000] <dbg> modem_hl7812: is_cmd_ready: 265 LOWPOWER VGPIO:1 GPIO6:1 UART_CTS:0
[00:02:03.938,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KTCPCFG=1,0,"52.213.132.116",8883,,,,0,,0]
[00:02:03.942,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET11: 0
+KTCPCFG: 2
[00:02:03.962,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KTCPCFG: (len:1)
[00:02:03.962,000] <dbg> modem_hl7812: on_cmd_sockcreate: +KTCPCFG: 2
[00:02:03.962,000] <dbg> modem_hl7812: on_cmd_sockcreate: look up new socket by creation id
[00:02:03.963,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:02:04.343,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KTCPCNX=2]
[00:02:04.344,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET11: 0
[00:02:04.369,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
+KTCP_IND: 2,1
[00:02:04.890,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KTCP_IND: (len:3)
[00:02:04.890,000] <dbg> modem_hl7812: on_cmd_sock_ind: +KTCP_IND ID: 2
[00:02:04.890,000] <dbg> modem_hl7812: allow_sleep: Keep sleep
[00:02:04.907,000] <dbg> modem_hl7812: allow_sleep: Keep awake
[00:02:04.907,000] <dbg> modem_hl7812: allow_sleep_with_timeout: Keep awake
[00:02:04.907,000] <dbg> modem_hl7812: is_cmd_ready: 265 LOWPOWER VGPIO:1 GPIO6:1 UART_CTS:0
[00:02:04.907,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:02:04.907,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+CCLK?]
[00:02:04.907,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
+CCLK: "24/07/07,17:38:14+08"
[00:02:04.912,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +CCLK: (len:22)
[00:02:04.912,000] <dbg> modem_hl7812: wait_for_modem_data: cur:23, exp:25
[00:02:04.962,000] <inf> modem_hl7812: RTC string: '"24/07/07,17:38:14+08"'
failure connection:
[00:01:56.636,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KCNXCFG=1,"GPRS","",,,"IPV4V6"]
[00:01:56.639,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
[00:01:56.656,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:01:56.656,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:01:56.656,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KTCPCFG?]
[00:01:56.657,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
[00:01:56.662,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:01:56.662,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:01:56.662,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KUDPCFG?]
[00:01:56.663,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
+KUDPCFG: 1,1,0,4184,0,"",0,0,1,0,3
[00:01:56.672,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KUDPCFG: (len:25)
[00:01:56.672,000] <dbg> modem_hl7812: on_cmd_sockcreate: +KUDPCFG: 1
[00:01:56.672,000] <dbg> modem_hl7812: on_cmd_sockcreate: look up new socket by creation id
[00:01:56.672,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:01:56.672,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:01:56.672,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+CGCONTRDP=1]
[00:01:56.674,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
+CGCONTRDP: 1,5,"net",10.149.39.64.255.255.255.128,10.149.39.1,10.105.16.254,10.105.144.254,,,,,,,
[00:01:56.687,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +CGCONTRDP: (len:118)
[00:01:56.687,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IP info: 118 1,5,"net",10.149.39.64.255.255.255.128,10.149.39.1,10.105.16.254,10.105.144.254,,,,,,,,,
[00:01:56.687,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IP string len: 29
[00:01:56.687,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IP addr: 10.149.39.64
[00:01:56.687,000] <dbg> modem_hl7812: on_cmd_atcmdinfo_ipaddr: IPv4 DNS addr: 10.105.16.254
[00:01:56.687,000] <dbg> modem_hl7812: hl7812_rx: HANDLE OK (len:0)
[00:01:58.687,000] <dbg> modem_hl7812: allow_sleep: Keep sleep
[00:01:58.687,000] <dbg> modem_hl7812: offload_bind: offload_bind
[00:01:58.687,000] <dbg> modem_hl7812: dns_work_cb: DNS ready
[00:01:58.687,000] <dbg> modem_module: pdn_event_handler: PDN_EVENT_ACTIVATED
[00:01:58.687,000] <dbg> LTE_HL7812: iface_ready_evt_handler: LTE is ready!
[00:01:58.688,000] <dbg> modem_module: pdn_event_handler: PDN_EVENT_ACTIVATED
[00:01:58.688,000] <dbg> LTE_HL7812: iface_ready_evt_handler: LTE is ready!
[00:01:58.688,000] <dbg> modem_module: state_set: State transition STATE_DISCONNECTED --> STATE_CONNECTED
[00:01:58.688,000] <dbg> cloud_module: state_set: State transition STATE_LTE_DISCONNECTED --> STATE_LTE_CONNECTED
[00:01:58.688,000] <dbg> cloud_module: connect_cloud: Connecting to cloud
[00:01:58.688,000] <wrn> cloud_module: CLOUD CONNECT RETRIES: 0
[00:01:58.688,000] <dbg> cloud_module: connect_cloud: Cloud connection establishment in progress
[00:01:58.688,000] <dbg> cloud_module: connect_cloud: New connection attempt in 32 seconds if not successful
[00:01:58.791,000] <dbg> aws_iot_integration: aws_iot_event_handler: AWS_IOT_EVT_CONNECTING
[00:01:58.791,000] <dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTING
[00:01:58.791,000] <dbg> modem_hl7812: offload_recv: offload_recv
[00:01:58.791,000] <dbg> modem_hl7812: offload_sendto: offload_sendto
[00:01:58.791,000] <dbg> modem_hl7812: allow_sleep: Keep awake
[00:01:58.791,000] <dbg> modem_hl7812: allow_sleep_with_timeout: Keep awake
[00:01:58.791,000] <dbg> modem_hl7812: is_cmd_ready: 265 LOWPOWER VGPIO:1 GPIO6:1 UART_CTS:0
[00:01:58.791,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+KUDPSND=1,"10.105.16.254",53,64]
CONNECT
[00:01:58.806,000] <dbg> modem_hl7812: hl7812_rx: HANDLE CONNECT (len:0)
[00:01:58.882,000] <dbg> modem_hl7812: send_data: Sent 64 bytes
NO CARRIER
[00:01:58.891,000] <dbg> modem_hl7812: hl7812_rx: HANDLE NO CARRIER (len:0)
[00:01:58.892,000] <dbg> modem_hl7812: allow_sleep: Keep sleep
[00:01:58.892,000] <err> aws_iot_netfeasa: getaddrinfo, error -11
[00:01:58.892,000] <err> aws_iot_netfeasa: client_broker_init, error: -10
[00:01:58.892,000] <dbg> aws_iot_integration: aws_iot_event_handler: AWS_IOT_EVT_CONNECTING
[00:01:58.892,000] <dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTING
+KUDP_NOTIF: 1,8
[00:01:58.893,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +KUDP_NOTIF: (len:3)
[00:01:58.893,000] <wrn> modem_hl7812: +K**P_NOTIF: 1,8
[00:02:00.688,000] <dbg> modem_hl7812: allow_sleep: Keep awake
[00:02:00.688,000] <dbg> modem_hl7812: allow_sleep_with_timeout: Keep awake
[00:02:00.688,000] <dbg> modem_hl7812: is_cmd_ready: 265 LOWPOWER VGPIO:1 GPIO6:1 UART_CTS:0
[00:02:00.688,000] <dbg> modem_hl7812: send_at_cmd: reset iface_ctx.response_sem: 0
[00:02:00.688,000] <dbg> modem_hl7812: send_at_cmd: OUT: [AT+CCLK?]
[00:02:00.688,000] <dbg> modem_hl7812: send_at_cmd: SEND ATCMD k_sem_take RET01: 0
+CCLK: "24/07/07,17:33:56+08"
[00:02:00.693,000] <dbg> modem_hl7812: hl7812_rx: HANDLE +CCLK: (len:22)
[00:02:00.693,000] <dbg> modem_hl7812: wait_for_modem_data: cur:23, exp:25
[00:02:00.743,000] <inf> modem_hl7812: RTC string: '"24/07/07,17:33:56+08"'
