I sent the at+gnssnmea=4,1000,0,1 command, and the module responded “CONNECT” to enter data mode.
But I can’t exit data mode by sending “++++”.
It’s stuck here.
Does anyone know how to exit data mode?
Best Regards,
Jerry Li
It’s stuck here.
Best Regards,
Jerry Li
I don’t see problem
ati3
HL7812.5.4.10.0
at
CONNECT
are we using same FW?
Did you add some guard time before sending the +++?
Hi @jyijyi
FW is not the same version.
I waited for more than 1 second before sending +++, and the result was stuck here, as shown below.
did you try the same FW as my test?
Same result.
Is there anything I should pay attention to? Or how to operate it?
are you using UART1?
are you using the HL dev kit?
are you using baud rate 115200?
We use UART 1 and USB and the result is the same, stuck here.
We used DevKit for testing, the baud rate we tried 115200 and 51200 but nothing changed
have you used an oscilloscope to check whether the “+++” is really sent out from the host?
Is it the same result to use tera term?
