HL7800-M.4.6.9.4 session id bug
Issue is intermittent, AT+KTCPCNX show error 910 even though sessions exist as is clear from AT+KTCPCFG?
@farrukh.h
Whats the full response to the below commands:
  • ati
  • at+cgmr
  • at+cpin?
  • at+cops?
  • at+creg?
  • at+cereg?
  • at+ktcpcfg?
  • at+ktcpstat?
can you please check? thank you.
we are getting error on multiple units, all on version 4.6.9.4, is there any way to downgrade fw version? thank you
@farrukh.h
Re the downgrade yes you can down grade the unit to any of the previous versions although 4.6.9.4 which you are using should be fine.
So a few questions and things to try.
  • I see you are using it as a secure client? I presume there are a load of commands where you have loaded the secure keys before hand?
  • You are using a URL to get to the server, do you have an actual IP address?
  • How many characters is the URL?
  • What is the setting for the at+kcnxcfg command?
  • When you try to send the at+ktcpcnx command does the error come back immediately or take a second or two?
  • Have you tried connecting to something like port 80 on google.com to make sure you have generic access (assuming you are using an APN with internet access)?
