HL78 AT+CSODCP with no CP CIoT EPS optimization
I am currently testing in NBIOT the sending of non-ip messages.
I have a problem when I configure my network in non “CP CIoT EPS optimization” mode.
When I send a message with the command “AT+CSODCP”, the HL78 does not take into account the mode without “CP CIoT EPS optimization” and always sends the messages as if “CP CIoT EPS optimization” was still activated.
Normally, it should do DRBs (S1-U data).
I have restarted the hl78 several times but without success.
Did I forget a command?
Here my hl78 config
HL7802.4.6.9
HL78xx.4.6.9.4.RK_02_01_02_00_137.20210615
2021/06/15 21:00:02
IMEI-SV: 3594590904284914
Legato RTOS: 18.09.6.ALT1250.rc8 2021/05/18 20:22:09
atSwi: 44.01
UBOOT: 01.03
Apps: RKAPP_02_01_02_00_120__c2a0a2a6e5dd44ea4710b32fe98e69dc72bab7ce
MAC: ALT1250_02_01_02_00_111_NB
PHY: 0.0.265675
PMP: 277307
SBUB: 1
SBFW: 1
RPuK: 53F7A48A
FPuK: 139A8E70
RBUB: 0
RBFW: 0
Hi @philippe.surbayrole
Please refer to the topic below to see if it helps you
Thank’s
But this solution work if i set the “CP CIoT EPS optimization”.
With Amarisoft we check the case when “CP CIoT EPS optimization” are disabled, and it’s seem that the HL78 don’t use the DRBs as mentioned in the 3GPP 24.301 specification.
